Grade 5 vs. Grade 8 Fasteners
I have been on a quite a few online email lists over the last 7 years or so, basically since they first came out. From the original Jeep-L list to the XJ-list to the Rockcrawler.com board, a common question comes up time and time again. No, I’m not talking about “how big a tire can I fit” or “which tire is better.” I’ll save those questions for the opinion section of everyone else’s website. I’m referring to the age-old question of “which fastener grade should I use?” It seems that everyone has an opinion on which grade is better but not many people can or will tell you why. Well, I’d like to explain the technical difference between a SAE Grade 8 (Grade 8) and a SAE Grade 5 (Grade 5) fastener.
Most people think a bolt is a bolt is a bolt. They see it as a machined chunk of metal that holds or attaches things. Fasteners (aka bolts or screws) are complex mechanically-engineered hardware. They are made using different materials, different thread types (i.e. coarse, fine, extra fine), various lengths, with grip or no grip (shank), different types (i.e. hex, 12 pt, carriage, etc.), different coatings (i.e. passivated, cadmium, dry film lube, etc.), various classes of fit (i.e. class 3), and multiple grades (i.e. grade 5, 8, etc.).
Bolts come with left or right hand threads, metric or SAE threads, different number of threads per inch (i.e. 20 or 28 for the same size fastener) and various versions of those (i.e. UNF versus UNJF). In addition, there are way too many military specs in existence to list them all here. So with all these differences, it’s no wonder most people don’t understand the difference between fasteners very well. Of all these differences, I’ll focus on the different grades since that is what most shade tree mechanics ask about.
First, you need to be able to identify bolts by the different grades when you go to the local hardware store. Grade 5 bolts have 3 marks or lines on the head that are in theshape of a “Y”. Grade 8 bolts have 6 marks on the head.
Second, the different grades have a meaning to them. It tells you how strong the fastener is. There are different types of strengths listed for each grade. Proof strength(about 90% of yield), ultimate tensile strength (bolt fails in stretch), yield strength (bolt begins to get a permanent set and changes cross-sectional area typically) and shear strength (bolt prevents parts from separating by using it’s shank or body as a stop).
Depending on how you are using the fastener, you would look at the appropriate and corresponding strength type. For example, bolts that attach a D-ring bracket to the bumper face of a vehicle would be critical in tension . So you would want to know what the tensile strength a particular bolt is. Bolts that attach winch-mounting plates are typically seeing mostly shear loads thus preventing the winch from departing from the vehicle during winching operations. In that case, shear strength is important to you.
Mark’s Standard Handbook for Mechanical Engineers lists Grade 5 fasteners as 120 ksi fasteners. This means the tensile strength is 120,000 lbs per square inch. It also lists Grade 8’s as 150 ksi fasteners meaning the tensile strength is 150,000 lbs per square inch. Also, the ultimate shear strength of a fastener is typically about 60% of its ultimate tension strength. So given a certain diameter (cross-sectional area) andstrength rating, someone can figure out how much load that fastener can carry in both tension and shear.
![]() Example of bolts under single shear load |
![]() Example of bolts under tension |
Let’s look at an example of where grade 5 and grade 8 bolts are subjected to single shear loads (winch plate reference).
Using a .250-inch diameter grade 8 fastener gives you the following shear capability:
A = Cross-sectional area of the fastener size (since bolt bodies/shanks have circular cross-sections, use area of a circle) = Pi x r2 where R (radius) = .250/2 = .125, therefore A = Pi x (.125)2 = .0491 square inches (in2)Capability in shear = 91,000 lbs / in2 x .0491 in2 = 4468 lbs
Capability in shear = 75,000 lbs / in2 x .0491 in2 = 3683 lbs
That’s a difference of over 750 lbs or over 1/3 ton. In this example you can clearly see that using a grade 8 fastener has a superior advantage over the grade 5. Therefore the result is if someone is using grade 5 bolts in a shear application like the winch plate example, they will fail almost 800 lbs earlier.
I’ve also heard the argument that grade 8’s are more brittle than grade 5’s and that’s why you shouldn’t use them. Well, first you need to understand what the term “brittle” really means. Brittleness in bolts is defined as failure at stresses apparently below the strength of the bolt material with little or no evidence of plastic deformation. Typically, fasteners are not brittle below 180 ksi ultimate tensile strength. Grade 5’s have an ultimate tensile strength of 120 ksi and a grade 8 fastener has an ultimate tensile strength of 150 ksi. This is why brittle is a relative term. Nearly all fasteners are considered ductile except some made from PH 15-6 Mo, 17-4 PH and 17-7 PH.
Going back to the D-ring on the face of the bumper example, you would want to know its tensile carrying capability. Calculating the tensile capability is not as easy as shear since the thinnest portion of the bolt is at the minor diameter of the threads (bottom of the thread “V”). So you need to know the nominal minor diameter of that particular fastener. That’s where military specification MIL-S-8879C comes in. It is titled “Screw threads, controlled radius root with increased minor diameter, general specification for”. It lists that and a lot more for almost all possible fasteners. MIL-S-8879C lists the nominal minor diameter of a .2500-28-UNF at .2065 inches. We can now calculate the A (area) of the cross-section:
A = Pi x r2 = Pi x (.2065/2)2 = .03349 in2>Grade 8 bolt capability in yield (stretch) = 130,000 lbs / in2 x .03349 in2 = 4354 lbs minimum
Grade 8 bolt capability in tension (failure) = 150,000 lbs / in2 x .03349 in2 = 5024 lbs minimum
Grade 5 bolt capability in yield (stretch) = 92,000 lbs / in2 x .03349 in2 = 3081 lbs minimum
Grade 5 bolt capability in tension (failure) = 120,000 lbs / in2 x .03349 in2 = 4019 lbs minimum
Again, you can see that the grade 8 will support over 1000 lbs more or a 1/2-ton more. But there’s something more important to note. The grade 5 fastener has already reached its ultimate load and FAILED BEFORE the grade 8 starts to yield or stretch. Therefore, the argument that you should not use grade 8’s because they are more brittle than grade 5’s is not a true statement in most applications.
Toughness is an important feature of a fastener. It is the opposite of brittleness and gives you an idea of how it will handle abuse without being damaged and eventually weakening the fastener or can cause fatigue to appear much earlier than normal. One way to “measure” toughness is by looking at the hardness rating of a fastener. The higher the number (Brinell, Rockwell …) the harder the material is and the tougher it is to damage. According to Marks’ Standard Handbook for Mechanical Engineers, Grade 5’s typically have a core Rockwell hardness of C25-C34 whereas a grade 8 typically has a core Rockwell hardness of C33-C39. Based on this, grade 8’s are tougher than grade 5’s.
Fatigue usually doesn’t play a big part in grade 8 or grade 5 fasteners since most steels are good for 2 million to 10 million cycles. Far more than you will ever winch or pull on. Here is a quick point about fastener fatigue. Almost all fastener fatigue failures are the result of improper (almost always too low) torque. Too low a torque will cause the fastener to pick up more load more often and eventually cycle it to failure. Therefore, you want to make sure you torque your fasteners to the appropriate level using a torque wrench and make sure to torque dry, clean threads. Lubricated threads significantly change the actual preload on the fastener and you risk over torquing it.
Due to space and time limitations, here is a chart showing you the tension and shear minimum capabilities of different grade fasteners relative to their size.
SAE Grade 5
SAE Grade 8
ARP Fastener
SPS Fastener
MS14181
SPS Fastener
Ultimate Tensile Capability of Fastener (ksi) |
120
150
160
180
220
260
Ultimate Shear Capability of Fastener (ksi) |
75
91
95
108
132
156
Fastener Diameter |
Typical Material
Med Carbon
Steel |
Med Carbon
Alloy Steel |
A286
CRES |
A286
CRES |
Inconel 718
MP35N
Super Alloy |
in. | thrds/in | |||||||
0.1640 | 32 | Tension Capability (lb) |
1468
1835
1957
2202
2691
3181
Shear Capability (lb) |
1584
1922
2007
2281
2788
3295
0.1900 | 32 | Tension Capability (lb) |
2169
2711
2892
3253
3976
4699
2126
2580
2694
3062
3743
4420
0.2500 | 28 | Tension Capability (lb) |
4007
5009
5340
6010
7347
8682
3682
4470
4660
5300
6480
7660
0.3125 | 24 | Tension Capability (lb) |
6440
8050
8590
9660
11807
13953
5750
6980
7290
8280
10120
11970
0.3750 | 24 | Tension Capability (lb) |
9888
12360
13180
14830
18127
21423
8280
10050
10490
11930
14580
17230
0.4375 | 20 | Tension Capability (lb) |
13338
16673
17780
20010
24453
28899
11270
13680
14280
16240
19840
23450
0.5000 | 20 | Tension Capability (lb) |
18139
22674
24190
27210
33255
39302
14730
17870
18650
21210
25920
30770
0.5625 | 18 | Tension Capability (lb) |
23028
28785
30700
34540
42218
49894
18640
22610
23610
26840
32800
38770
0.6250 | 18 | Tension Capability (lb) |
29218
36524
38960
43800
53568
63307
23010
27920
29150
33130
40500
47900
0.7500 | 16 | Tension Capability (lb) |
42726
53408
57000
64100
78331
92573
33130
40200
42000
47700
58300
68900
0.8750 | 14 | Tension Capability (lb) |
58434
73043
77900
87700
107129
126607
45100
54700
57100
64900
79400
93800
1.0000 | 12 | Tension Capability (lb) |
75968
94961
101300
114000
139275
164598
58900
71500
74600
84800
103700
122500
These examples show how much of a load can be carried by the fastener BUT you need to make sure the parent material is strong enough to handle the loads, as well, otherwise it will fail. Industry practice is to apply a safety factor to address any unknowns and/or combined load cases to give you an adequate margin of safety.
Another good point to make is to never reuse fasteners after they have been subjected to loading or the elements. Corrosion can cause a fastener to fail well below its initial strength. So be smart and use only new fasteners when installing or reinstalling some cool new widget on your rig.
Getting back to the original question, “which fastener grade should I use?” I hope it’s very clear by now that grade 8 fasteners are far superior to grade 5 fasteners. If this is so, then why do the automotive manufacturers use some grade 5 fasteners? The automotive OEM’s use what it needs to be safe and nothing more since there is a difference in cost between grade 5 and grade 8 (or metric 8.8 and 10.9). Since the OEM’s manufacture millions of vehicles each year, the difference in a few cents per fastener adds up to a lot for them. However, as an individual who has spent some serious coin on a winch or lift kit, I wouldn’t let the few cents difference in the cost of a grade 8 versus a grade 5 fastener make up my mind as to which fastener I would use.
We have a saying where I work that seems an appropriate answer to this age-old question.
“When in doubt, make it stout!”
