<%@LANGUAGE="VBSCRIPT"%> ROCKCRAWLER.com - Big Daddy Offroad Introduces CJ Steering Box Brace
Big Daddy Offroad
Big Daddy Offroad Steering Box BraceHigh Point, NC - One of the largest problems with lifted CJ's and larger-than-stock tires is the weak, stamped steel, factory steering gearbox bracket. It only takes a short period of time for these pieces to start fatiguing and cracking.
To solve the inherent weakness of these factory pieces, Big Daddy Offroad have developed the Big Daddy Steering Box Mounting System. This bracket is formed of 3/8" laser cut plate steel and carefully assembled in a precise fixture for a perfect fit with no drilling required. This unit is double-gusseted where it counts and factory mounting points are utilized.
This bracket allows you to 4-wheel without worrying about the woes of the factory set-up.
The kit includes the bracket, Grade 8 studs for anchoring the box to the bracket, and Grade 8 hardware for mounting the bracket to the chassis, along with detailed instructions.
Contact: Big Daddy Offroad
©2002 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
