Carson
City, NV -Nth Degree Mobility has designed
the strongest, highest clearance skidplate you can buy,
and no body lift is required! Many versions of the Tummy
Tucker are available for your YJ, TJ, and Rubicon to fit
most t-cases and transmissions. All TTs are ¼”
steel with multiple gussets for maximum strength. Each kit
comes with a repackaged transmission bracket and new dual
isolators which sit to the side of the transmission, giving
you maximum clearance.
The main YJ/TJ version has only 1.25”
drop, and the Rubicon version has an additional .75”
drop under the t-case front output. There is also a flat
rail-to-rail version available for those with a body and
motor mount lift. Easy to install, only minor floor denting
is required for Rubicons, and a C/V shaft is required for
all models. No other modifications or additional equipment
necessary. There is also a DIY version that makes it possible
to adapt a TT to whatever non-stock drivetrain you have
(fabrication required).
For
more information, contact: Nth Degree Mobility:
(775)885-8454
www.nthdegreemobility.com
