<%@LANGUAGE="VBSCRIPT"%> ROCKCRAWLER.com - BesTop Powerstep Makes Entry/Exit Easier
Bestop PowerstepBROOMFIELD, CO - Now you see it…now you don’t. The new Bestop® Powerstep™ is the only full-length running board that disappears under the truck when not in use.
With the doors closed, there is no visual cue Powerstep is installed on the vehicle, retaining the clean, uncluttered style. Powerstep is hidden and protected under the truck, flush with the rocker panel, virtually eliminating clearance issues for those who venture off-road. While stowed, the Powerstep is also up out of the way of road grime so you won’t soil your pant legs as you brush by.
Open the door, however, and the Powerstep extends to greet you in just one second. Powerstep can extend to the optimal ergonomic height for proper entry and exit without sacrificing ground clearance. By placing the step at the optimum height and distance from the door opening, Powerstep provides a natural step similar to steps found in your home.
The Powerstep is activated by an electronic signal from the truck’s factory door sensor switches, so operation is automatic. Though elegant in operation, Powerstep is built to rugged standards and can handle up to 600 pounds per side. The full- length step features a no-slip surface for sure-footed access regardless of weather.
A heavy-duty weatherproof motor features anti-pinch technology for an extra margin of safety. All components are OEM quality and corrosionresistant for long service life. The Powerstep is designed to operate normally in all weather conditions, including extreme temperatures. It has been tested in conditions ranging from a sweltering +200°F to a frigid
The Powerstep is engineered, designed and manufactured by the people at AMP Research, a technology-driven company located in southern California. In a strategic alliance, Bestop will brand, market and distribute the Powerstep for AMP in North America.
Fit, form, and function: They define the Bestop f3 Method. Adhering to these principles means producing aftermarket truck accessories that install like OE, offer refined vehicle-specific engineering and reliably serve a practical purpose. It’s the way Bestop has done business for 50 years.
Bestop Inc. is part of Decoma International owned by Magna International, one of the largest automotive parts manufacturers in the world. Bestop manufactures aftermarket soft tops, accessories and hard tops for small
sport utility vehicles and functional accessories for pickup trucks. For more information on the Bestop product line, call (800) 845-3567 or go to www.bestop.com.
©2004 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
