Superlift
Superlift Unveils Suspension Kits for 2007 Jeep Wrangler JK
Superlift JKWest Monroe, LA - Superlift has two lift systems and a variety of related accessories for new Jeep JK Wranglers, including 2-door, 4-door and Rubicon models.
Depending on configuration, the various JK Wranglers have 22 available OE spring rates. With this in mind, Superlift's 2" lift system uses thicker-than-stock coil-spring isolators as an effective way to easily fit 33x12.50 tires. The kit also includes bumpstop spacers; optional Superide shocks improve control and allow 2 extra inches of extension travel.
The Superlift 4" kit uses pre-set coil springs to clear up to 37x12.50 tires (depending on wheel width and offset). A heavier rear spring is offered for 4-door Wranglers, and it can be used for 2-door JKs that often carry loads.
To control roll and yaw, a front adjustable track bar is included; the standard Superlift kit uses a rear track-bar relocation bracket since steering geometry isn't an issue. Also included are rear axle-to-frame links to restore wheelbase.
Ride and handling are addressed with new alignment cams to correct caster and extended urethane bumpstops to prevent suspension over-compression. The kit also includes factory-style (greasable) extended swaybar links in addition to extension brackets for the brake hoses and emergency-brake cables. Superide Standard shocks with yellow boots are included. Other boot colors are available, as are premium monotube Superlift SS and SSR (remote-reservoir) shocks.
Superlift JKSeveral options allow JK owners to get even more from their Jeeps. Front and rear Rockrunner swiveling link arms -- made from .188" wall-thickness DOM tubing -- increase suspension articulation. This design offers several advantages over arms that have Heim ends: longer service life, greasable urethane bushings at the axle ends, quiet operation, greater vibration damping and adjustable length for dialing in alignment.
Swaybar Quick-Disconnects are another performance upgrade. These threaded-type disconnects use no-tools-required pull pins and feature greasable upper ends. An optional steering stabilizer kit is available, and extended-length Bulletproof brake hoses have braided-steel jackets and Kevlar-reinforced linings for optimal durability and pedal feel.
Other available accessories include an adjustable rear track bar for up to 4" of lift and eXtreme Rings zinc-plated diff cover protectors.
All components are backed by Superlift's Limited Lifetime Warranty.
For more information, contact your nearest Superlift dealer, call 800-551-4955 to speak with Superlift’s sales and tech support staff or visit www.superlift.com. Superlift Suspension Systems, 300 Huey Lenard Loop, West Monroe, LA 71292, 800-551-4955 toll-free, 318-397-3040 fax.
©2006 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
