Superlift
Superlift Introduces Long Arm Suspension for Jeep TJ
Superlift TJ Long ArmWest Monroe, LA: Superlift announces high-performance suspension systems for Jeep TJ Wranglers and Wrangler Unlimiteds. These Rockrunner Long-Arm Series lift are available in two heights: 4" and 6".
Both kits center on high-articulation link arms. Two full-length Rockrunner arms at each corner provide exceptional clearance, full steering and incredible suspension flex. Rockrunner arms feature internal swivels that out-travel Heim ends; steel-encased rubber bushings at certain link mounting points ensure bind-free articulation, vibration dampening, extended service life and noise-free operation. Further, the arms' flat operating angle creates ideal weight transfer characteristics and alignment geometry. These arms are made of .188"-wall DOM tubing (lowers 2" OD; uppers 1.5” OD) and laser-cut .25"-thick plate steel. The Rockrunner arms bolt directly to the TJ axles; optional weld-on brackets are offered to accommodate popular axle swaps. Also available are longer female swivel ends that increase wheelbase 1", 2" or 3".
Lift comes from taller-than-stock coil springs. Base Rockrunner kits also include compression-travel-control components, four threaded-style swaybar quick-disconnects, extended-length braided-steel brake hoses with Kevlar-reinforced liners, a dropped pitman arm, and adjustable track bars with mounting brackets. The Superlift steering system works with the tie-rod mounted either above or below the knuckle.
The Rockrunner system's arms anchor to a 2-piece skidpan assembly. A 3/16"-thick inner pan serves as a transmission support, and the full-width 1/4"-thick primary pan installs separately to make driveline maintenance easier. Flush-mounted fasteners maximize ground clearance.
Superlift TJ Long ArmMany options and upgrades are available. First and foremost, TJ owners have three shock choices: Superlift Superide, monotube Superide Select Series (SS) or Superide Select Series with remote reservoir (SSR). SSRs can be combined with an optional coilover conversion. This improves ride quality and reduces lift force when climbing obstacles thanks a noise-free, progressive-rate single coil on each shock.
Other available options include an eXtreme Clearance Flat Skidpan (available for high-pinion applications), Superlift eXtreme Ring diff cover protectors and the TruSpeed speed-sensor recalibrator.
All components are backed by Superlift’s Limited Lifetime Warranty.
For more information, contact your nearest Superlift dealer, call 800-551-4955 to speak with Superlift’s sales and tech support staff or visit www.superlift.com. Superlift Suspension Systems, 300 Huey Lenard Loop, West Monroe, LA 71292, 800-551-4955 toll-free, 318-397-3040 fax.
©2006 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
