1971 Toyota Landcruiser 4x4 Rock Crawler off road vehicle:
LS1 engine.
SM465 Transmission.
Advance Adaptor heavy duty clutch.
Advance Adaptor 4 speed Transfer case.
Mickey Thompson Baja Claw 19.5/46-20
Front Dynatrac Pro 60 high pinion competiton shaft 60F Detroit locker 35 spline 5.38 ratio heavy duty disk brakes assemblies with 8 on 6.5 bolt pattern. Heavy duty outer ends package includes high strength knuckles, spindles and wheel hubs, competition steering hardware.
Rear Dynatrac Pro 80 rear axle assembly, 35 spline, 1.5 inch diameter, 1 ton heavy duty full float alloy axle shaft assemblies. Detroit locker, heavy duty disc brakes, center pinion, heavy duty full float spindles.
Howe hydraulic steering.
Stazworks military style double beadlock rims.
Warn 9.0 RC winch in front and Winch in rear (both suck down)
Fox coil over with Eiback springs.
Master craft seats.
Crow Harnesses.
Aluminum covered double battery set up with separate kill switches.
Aluminum fuel cell.
Aluminum oversized radiator and high flow/velocity fan with override on switch.
Auto meter gauges and high quality switches.
2 Tuffy security version 2 lockable consoles one is a center console with a lockable stereo compartment and cup holders and the other over the dash.
Stereo, cd, ipod connection amplifier and speakers.
Hose down Floor and tub bedliner.
Flowmaster exhaust.
Professional paint job, strip down to bare metal and painted.
Fire extinguisher.
Hella lights.
Under carriage and side lights.
Landcruiser is set up for a "Premier" on board welder.
Landcruiser is set up for a "Dometic" fridge/freezer.
Also have a 20 foot flat bed trailer for sale to haul the crawler or any full size Jeep with a UTV such as a Rhino or a polaris RZR 2 seater.
This crawler was professionally built by Marlin Crawler and has been used 3 times.
All parts installed with the exception of the engine (has 58k miles) are all new(no used or junk yard parts) Have receipts and documents.
Truck has a California license plate and is smog exempt.
60,000 OBRO (Or best reasonable offer) Serious inquiries. No trades.
Contact: tomnehme@aol.com
More pictures:
http://s454.photobucket.com/user/tomnehme/library/Landcruiser Rock Crawler?sort=6&page=1
