1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1987 chevrolet suburban shifting problems
Discussion in 'Wheelers Tech' started by trevor47, Feb 10, 2013.
  1. trevor47
    trevor47 Member
    Feb 10, 2013
    5
    I have a 1987 Chevrolet suburban v10 4wd with a 351, it's been experiencing a problem that seems to be when it goes to shift into a higher gear it's as if it slips into neutral, the revs rise quickly with no gain in speed. Flooring the gas seems to get it to up shift but at that point it is revving way too high. Putting in in 4wd seems to help slightly but does not completely alleviate the problem. Would this be a transmission or transfer case problem and should I replace either? I changed the transmission oil which hadnt been replaced in a long time and the oil that drained out was slightly black.
  2. Satanic Mechanic
    Satanic Mechanic Member
    Feb 7, 2013
    13
    Did you change the filter also?
  3. woody
    woody eternal noobie Staff Member Media Partner
    Oct 12, 2010
    503
    Wisconsin
    what the heck Chevy has a V10 351??
  4. trevor47
    trevor47 Member
    Feb 10, 2013
    5
    The model designation is v10 the engine is the standard 351 v8
  5. trevor47
    trevor47 Member
    Feb 10, 2013
    5
    V10 is the model designation, it has the standard 351 v8 and yes the filter had been replaced
  6. woody
    Oct 12, 2010
    503
    Wisconsin
    350 V8 actually, for that vintage...351 is a Ford motor size :)
    how many miles on it? Original trans? Very likely it needs a rebuild, the trans from that vintage is likely a 700R4 and is not notorious for lasting a long time without needing upgrades.
  7. trevor47
    trevor47 Member
    Feb 10, 2013
    5
    It is a 700r4 and it is the original transmission, mileage I'm not sure as the odometer is broken but it's well into the 100,000s if not closing in on 200,000
  8. Big Red 88
    Big Red 88 Active Member
    Aug 4, 2012
    42
    I'm a trans rebuilder and to me it sounds like you burned up your 3-4 clutch pack... Extremely common problem with those
  9. trevor47
    trevor47 Member
    Feb 10, 2013
    5
    Would that require a rebuild of the whole transmission?
  10. Big Red 88
    Aug 4, 2012
    42
  11. woody
    Oct 12, 2010
    503
    Wisconsin
    Yep...you are stuck rebuilding...guessing $6-700 for a shop to do it?
  12. VMAN
    VMAN Member
    Oct 20, 2012
    18
    You shouldn't have changed the fluid. All your clutch material was in the old fluid. Time for a rebuild.
