Larson Electronics has announced the release of a powerful new LED spotlight designed to mount to the rails, cages and roll bars commonly found on marine craft and utility and all-terrain vehicles. The BCML-LED25WRE bar clamp mounted spotlight offers high light output in a durable, low profile housing and operates on any voltage from 12 to 32 volts.
The BCML-LED25WRE LED bar clamp mount spotlight from Larson Electronics is an ideal lighting solution for hunters, outdoorsmen, military, and law enforcement professionals who desire a powerful spotlight that can be easily operated while providing high power and rugged durability. This LED spotlight produces a 1000 foot long beam with 2750 lumens of bright light while drawing only 25 watts. A single CREE twenty-five watt LED produces 2750 lumens and is paired with high purity 10° optics to produce a tightly focused spot beam with limited spread.
These bar clamp mount spotlights are IP68 rated and waterproof to three meters, sealed against intrusion by dust and dirt and ruggedly constructed to withstand demanding environments and applications. It is constructed of extruded aluminum and features rubber isolated mounts and unbreakable polycarbonate lenses to provide durability and resistance to vibrations, impacts, waves, hard rains, sand and high winds.
The BCML-LED25WRE is mounted on the end of a 10” shaft. An aluminum bar clamp is also mounted to the shaft to simplify mounting. The top portion of the mount has a through hole that enables the operator to pass one of two ¼ -20 bolts through it and secure that stud with a Nylock nut. Small machine screws secure the bottom half of the clamp to the top portion. The installer simply affixes the light to the top portion and places the assembly on the rail or bar. The bottom portion is positioned and secured with the machine screws, cinching the clamp tightly to the bar.
“Our new bar clamp mounted LED lights were designed with a high volume of hunters looking for a light to mount on their ATV’s,” Rob Bresnahan with Larsonelectronics.com said. “This adjustable LED spotlight provides the intense light output and durability that is needed to withstand the rough conditions that an ATV goes through.”
Larson Electronics carries an extensive line of LED spotlights, LED hunting lights, colored LED lights, portable work lights and industrial grade LED area lights. You can view Larson Electronics’ entire line of lighting by visiting them on the web at LarsonElectronics.com. You can also call 1-800-369-6671 to learn more about all of Larson Electronics’ lighting products or call 1-214-616-6180 for international inquires.
The post New 25 Watt Bar Clamp Mounted LED Spotlight Released by Larson Electronics appeared first on RockCrawler 4x4 and Offroad Magazine.
- New Bar Clamp Mounted LED Spotlight Released by Larson Electronics
- 90 Watt High Intensity LED Light Bar from Larson Electronics Provides Impressive Performance
- Larson Electronics Reveals a New Five Foot LED Task Light with End Connectors
