Ramsey REP 8000e Winch |
As the pastime
of four-wheeling gets larger and larger, more and more people are
finding themselves in a situation where they need a good solid winch
on their vehicle. Winches provide everything from occasional recovery
to pure safety - whether you or a friend is teetering over the edge
of a cliff or stuck in the mud. In many cases, a winch may simply
provide peace of mind, knowing that you can get out of a situation
under you own power if the need arises.
A few years
ago only about half or less of trail rigs had winches and very
few people knew how to properly use one. Today even entry-level
and new vehicles are sporting winchs of all types.
One drawback
to putting a winch on for many people is simply the price. A good-quality
winch from any of the major manufactures could run well over $600
and may even be as high as $1,000 depending on the pull rating,
the model, and of course, how popular that winch is. And the money
doesn't really stop there, as most rigs also require a good solid
mounting plate that will work with that winch.
A number of
manufacturers (including a flood of knock-off's from overseas)
have begun manufacturing entry-level winches aimed specifically
at the four-wheeling crowd. These winches are typically about
a third of the price of the major brands/models or substantially
discounted, compared to buying a traditional 8000 lb winch.
To
compete with and perhaps "one up" their competition,
Ramsey has introduced a new line in their popular REP series called
the REP 8000e (12V Part# 111062). According to Ramsey, this "hard
working and dependable winch is made in the USA and features a
faster line speed and lower AMP draw at full load than the competitions'
entry level designs."
Ramsey
REP 8000e Feature list:
Proven 3-stage planetary gear system design for fast line speed
Motor and solenoids are grounded directly to battery
Strong
automatic load-holding brake for strength
Cam
action clutch disengages planetary gear system for free spooling
Weather-resistant
solenoid assembly
12
ft. wire pendant remote
6
ft. (1,83 M) 2 gauge battery cables with connectors
Hawse
fairlead
Limited
lifetime warranty
Made
in the USA
Specifications:
Rated line pull (single line) 8,000 lbs. (3,620 kgs)
Gear reduction ratio 294:1
Motor
Permanent magnet (12V)
Overall
dimensions (LxWxH) 20.86" x 6.00" x 6.38" (530
mm x 152 mm x 162 mm)
Drum size Diameter 2.5" (63 mm) Length 9" (228 mm)
Weight
75 lbs. (34 kgs)
Cable
supplied 95 ft. (29 m) of 5/16" (8 mm) galvanized aircraft
cable with replaceable clevis hook
Mounting
bolt pattern 10.00± .015 IN X 4.50± .015 IN (254,0
MM x 114,3 MM)
Line
Speed & Amp Draw - First Layer |
| Line
Pull |
lbs. |
No
Load |
1,000 |
3,000 |
5,000 |
6,000 |
8,000 |
kgs |
450 |
1,350 |
2,260 |
2,710 |
3,620 |
| Line
Speed |
fpm |
15 |
13 |
11 |
9 |
8 |
6 |
mpm |
4.5 |
4.0 |
3.4 |
2.7 |
2.4 |
1.8 |
| Motor
Current |
amps |
40 |
80 |
140 |
200 |
230 |
310 |
Line
Pull & Cable Capacity |
| Layer
Of Cable |
1 |
2 |
3 |
4 |
| Rated
Line Pull Per Layer |
lbs. |
8,000 |
6,500 |
5,500 |
4,800 |
kgs |
3,620 |
2,940 |
2,490 |
2,170 |
| Cable
Capacity Per Layer |
ft. |
15 |
40 |
70 |
95 |
m |
4 |
12 |
21 |
28 |
All
these specifications don't really help you out too much in the real
world. I mean, after all, a hand winch looks good on paper but might
require more muscle than you can put out if the rig is stuck in
deep mud or at an extreme incline. Having said that, let's get on
to the what the Ramsey REP 8000e can do; outside; on the trail;
in the real world. First, we have to get it out of the box.
Ramsey REP 8000e As it's packaged. |
I
won't attempt to try and explain how a winch should or should not
be installed. Bumper-mounted installation of a winch is fairly straight
forward and requires no special tools. Every manufacturer that I
have seen has decent instructions on how to hook up your winch.
Essentially,it is as simple as supplying a good mounting plate and
running two cables to your battery.
Of
course, installation can become much more integrated if you wish
to run in-cab controls or removable winches. For normal installation,
everything but the winch mounting plate is included with the REP
8000e. They even toss in a Hawse fairlead. In our case, we actually
installed this winch on the back of our test Jeep, which required
us to use 12 foot leads and much heavier cable then would normally
be used and included for a typical 4 or 6 foot cable run.
You can see the thickness of the cables we used |
Note the copper ends on our new cable. |
The important
part after hooking up a winch regardless of front, rear or removable
is to make sure that there are no places where the wires can be
chaffed or cut. A winch that's not working when you need it is
probably worse then having no winch at all. Now then let's get
on to the testing...
