AMSOIL Announces New Engine and Transmission Flush
by / 1 Comment / 20 View / March 31, 2010
New AMSOIL Engine and Transmission Flush is a detergent-based flush product that is formulated to improve fuel economy, operating efficiency and reduce emissions in gasoline and diesel engines, and automatic transmis­sions. Its potent formula cleans sludge and deposit build-up, promoting lower operating temperatures and reduced oil consumption. Detergent-based AMSOIL Engine and Trans­mission Flush safe on parts and can be easily disposed of with waste oil.
Over time deposit buildup can cause power and performance loss, resulting in restricted oil flow to vital engine and transmission parts. AMSOIL Engine and Transmission Flush is a multi-use solution that dissolves and disperses sludge, varnish and deposits in a single treatment.
AMSOIL Engine and Transmission Flush is an advanced formulation with light base oil technology plus powerful detergents and dispersants. It prepares engines and transmissions for the installation of new motor oil or transmission fluid while restoring peak performance and power.
In addition, AMSOIL Engine and Transmission Flush loosens sticky valves, helps quiet lifter noise. In transmissions it helps unclog fluid passages, improves erratic shifting, and promotes smoother operation and longer transmission life.
AMSOIL Engine and Transmission Flush is recommended for both diesel and gasoline engines, and automatic transmissions. It is not recommended for CVT transmissions or differentials. One bottle contains 16 fluid ounces.
About the Company: AMSOIL has been the recognized leader in synthetic lubrication since 1972.  For more information about AMSOIL synthetic motor oils contact your nearest AMSOIL distributor, or call AMSOIL at (715) 392-7101 or 1-800-777-8491.  AMSOIL INC., AMSOIL Building, Superior, WI 54880, or go to www.amsoil.com.
One Comment
  1. Fantastic post.Thanks Again. Much obliged.
