Superlift Releases Chevy/GMC 8-Inch Lift System
by / 0 Comments / 37 View / March 19, 2010
Superlift is now shipping 8-inch lift kits for 2007-current Chevy/GMC 1500 pickups. Available for 2WD and 4WD Silverados/Sierras, the Superlift 8-inch kit cleanly makes clearance for 35″-tall tires. Minor wheelwell trimming clears 37s. The system is compatible with GM’s StabiliTrak Electronic Stability Control (ESC). All load-bearing bracketry is made from laser-cut .25″-thick steel. Full-width control-arm crossmembers incorporate kicker braces for added strength. Major front components include replacement iron knuckles and premium gas-charged struts. The 4WD systems don’t require cutting/modifying the differential, and the OE front axleshafts and driveshaft are retained.
Rear lift blocks ensure that factory ride quality and load-carrying capacity are retained. Premium Superide replacement springpacks are one of many options.
For more information, contact Superlift Suspension Systems, 800-551-4955, www.superlift.com.
