Rock Assault™ 3.0L V6 Power Steering Pump Kit
by / 0 Comments / 28 View / August 31, 2010
We all know that the stock pump on a 3.0 is just not enough to turn big tires or run a ram assist and when you try and drill out the inlet to get more volume the result is a loud pump followed by pump failure. A new Toyota stock pump puts out around 1,300 PSI at only one gallon per minute. Our Rock Assault™ Pumps put out 1,450 and 1,650 PSI at 4-4.5 GPM, which is more than enough volume to provide you with the steering power that you will need to turn big tires or run a ram assist or full hydraulic steering system.
Trail-Gear has handpicked each component in this kit to ensure quality, ease of installation, and durability. This kit ships complete with all parts included and full color installation instructions.
Application Notes: This pump and bracket is designed to fit all Toyota V6 3.0 Pickups and 4Runners from 1989-1995. This kit does not work with 3.0 Tacoma’s. This kit will not work on 4Runners with a functioning AC, because the AC cooling fan must be removed for the placement of the PS Pump cooler.
http://www.trail-gear.com/steering-pump-kits#v6
