Perfectly Balanced – Jeep XJ X-Series Kits Graduate to N2.0
by / 0 Comments / 148 View / August 22, 2011
DYERSBURG, TENNESSEE Rough Country’s popular 4.5″ and 6.5″ X-Series Suspension Lifts now join the ranks of N2, offering a balanced ride for both on and off-road use. The new 4.5″ X-Series N2 features a transfer case drop kit, adjustable track bar, stainless steel brake lines, and sway-bar disconnects. A set lifted coil springs and all-new rear lifted leaf springs help your XJ gain a total of 4.5″ in lift – plenty of clearance for 32″ tires. This X-Series kit features Rough Country’s X-Flex Control arms in the front upper and lower position. X-Flex Arms are fully adjustable, and feature a ball-in joint, massive 2.5″ diameter body, and huge 1.25″ threads. X-Flex Control Arm Joints have long offered considerable range, strength, and safety for off-road applications – but it doesn’t stop there. X-Flex Joints now feature Adjustable Retainer Rings, allowing you to preload the bushings by compressing them prior to install. These NEW bushings are fitted with interlocking grooves that completely encase the ball joint for a firm grip. Made of high-quality 88 Durometer Urethane, these bushings retain the memory of their original shape, are weather resistant, and offer a much longer lifespan. This X-Series Lift now also offers N2.0 shocks; outfitted with rubber bushings and armed with 10-stage velocity sensitive valving, chromed hardened 9/16″ piston rods, and massive 1 3/8″ bores; allowing for a super smooth highway ride and outstanding control in rugged off-road situations – all from the same shock. So if you’re looking for longevity and an uncompromised ride, look no further. Rough Country’s X-Series N2 features the best of the best in off-road hardware. The 4.5″ X-Series N2 Lift retails for $829.95, and the 6.5″ version retials for $899.95.
Rough Country Suspension® Products is owned by Heckethorn Products® which boasts a rich history in the automotive aftermarket, including the invention of the first steering stabilizer for military Jeeps in the 1950s. As a complete supplier, Rough Country Suspension Products offers retailers, wholesalers, and consumers an opportunity to purchase easy to install off-road products the market is demanding.
CONTACT:
1400 Morgan Rd.
Dyersburg, TN 38024
800-222-7023
www.roughcountry.com/
