TJ Track Bar Relocation Bracket
PROMOTES PROPER ANGLES FOR IMPROVED HANDLING
tjDYERSBURG, TENNESSEE— There’s an easier way to get the right angles after lifting your Jeep TJ, thanks to Rough Country’s new TJ Track Bar Bracket. This heavy duty bracket lets you keep your track rod in the stock location on the axle. Utilizing this bracket alleviates the task of drilling a new axle mount point so close to the original, meaning a faster and easier install with more peace of mind. This kit works perfectly with a stock track bar on a 4″ lift, or an adjustable, factory-style track bar on 6″ lifts. This kit also includes an extended pitman arm, allowing you to drop the drag link thus promoting a longer lifespan for tie rod ends – a common weak point on lifted Jeeps. Made with durable 1/4″ plate steel, the TJ Track Bar Bracket is ready to protect at all times, even under intense off-road action. This kit retails for $99.95
Formed in early 1970’s, Rough Country Suspension® Products was a founder of the off-road industry and is one of the fastest growing manufacturers and marketers of lifted suspension packages and off-road accessories for 2wd and 4wd trucks and SUVs. Rough Country Suspension® Products is owned by Heckethorn Products® which boasts a rich history in the automotive aftermarket, including the invention of the first steering stabilizer for military Jeeps in the 1950s. As a complete supplier, Rough Country Suspension Products offers retailers, wholesalers, and consumers an opportunity to purchase easy to install off-road products the market is demanding.
CONTACT:
1400 Morgan Rd.
Dyersburg, TN 38024
800-222-7023
www.roughcountry.com/
