Warn Industries Introduces 12 New Powersports Winches for ATVs and Side x Sides
by / 0 Comments / 58 View / August 16, 2012
Adding to its industry leading array of winches for off-roading and vehicle recovery, Warn Industries today launched two new lines of powersports winches that provide premium components and unequaled performance.
The WARN(R) ProVantage and WARN Vantage lines, intended for both ATVs and Side x Sides, include a total of 12 new products. Warn Industries was the first company to introduce winches designed specifically for powersports applications back in 1988.
Those looking for the ultimate powersports winch need look no further than the WARN ProVantage lineup. Available in capacities ranging from 2,500 lbs. to 4,500 lbs. and a choice of durable aircraft-grade wire rope or lightweight, easy-to-handle synthetic rope, these winches are built using premium components and offer market-leading performance and features.
ProVantage winches features a powerful permanent magnet motor, a smooth, reliable three-stage planetary gear train and metal gear housing, an easy-to-use clutch control dial, full sealing to keep the elements out, a patented roller disc brake for excellent control while winching, and a corrosion-resistant black powder-coated finish with a unique black hook and tie rods. These winches have a Limited Lifetime warranty on mechanical parts and a three-year warranty on electrical components.
ProVantage 2500 and 2500-S
  • — 2,500 lb. capacity–great for ATVs
  • — ProVantage 2500: 50′ of 3/16″ aircraft-grade wire rope and unique plow roller fairlead for reduced rope wear.
  • — ProVantage 2500-S: 50′ of 3/16″ lightweight, easy-to-handle synthetic rope and attractive double powder-coated hawse fairlead.
  • — Mini rocker control switch with plug for corded remote (remote sold separately).
  • — New Black-Out finish provides superior corrosion resistance
ProVantage 3500 and 3500-S
  • — 3,500 lb. capacity–ideal for heavier ATVs as well as Side x Sides
  • — ProVantage 3500: 50′ of 3/16″ aircraft-grade wire rope and unique plow roller fairlead for reduced rope wear.
  • — ProVantage 3600-S: 50′ of 3/16″ lightweight, easy-to-handle synthetic rope with attractive double powder-coated hawse fairlead.
  • — Corded remote and mini-rocker control switch with integrated socket.
ProVantage 4500 and 4500-S
  • — 4,500 lb. capacity–the highest in the WARN powersports lineup–and specific for Side x Sides.
  • — ProVantage 4500: 55′ of 7/32″ aircraft-grade wire rope (the longest in the WARN powersports winch lineup) with unique plow roller fairlead for reduced rope wear.
  • — ProVantage 4500-S: 50′ of 7/32″ lightweight, easy-to-handle synthetic rope with attractive double-powder-coated hawse fairlead.
  • — Includes illuminated dash-mounted control switch and corded remote.
WARN Vantage Winches: Affordability meets class-leading performance
WARN Vantage powersports winches offer class-leading performance, affordability, and capacities from 2,000 lbs. to 4,000 lbs. All WARN Vantage winches are available with either durable aircraft-grade wire rope, or lightweight easy-to-handle synthetic rope. Features include fully sealed permanent-magnet motors and planetary drivetrains, high-strength composite gear housings, and a five-year warranty on mechanical components, and a one-year warranty on electrical items.
Vantage 2000 and 2000-S
  • — 2,000 lb. capacity–great for smaller ATVs.
  • — Differential planetary gear train provides excellent performance and a self-locking brake.
  • — Vantage 2000: 50′ of 5/32″ aircraft-grade wire rope with roller fairlead
  • — Vantage 2000-S: 50′ of 5/32″ lightweight, easy-to-handle synthetic rope with powder-coated hawse fairlead.
  • — Includes handlebar-mounted mini rocker control.
Vantage 3000 and 3000-S
  • — 3,000 lb. capacity–great for bigger ATVs and Side x Sides.
  • — Reliable three-stage planetary gear train and mechanical spring brake for great control.
  • — Vantage 3000: 50′ of 3/16″ aircraft-grade wire rope with roller fairlead
  • — Vantage 3000-S: 50′ of 3/16″ lightweight, easy-to-handle synthetic rope with powder-coated hawse fairlead.
  • — Includes handlebar-mounted mini rocker switch and corded remote control.
Vantage 4000 and 4000-S
  • — 4,000 lb. pulling capacity–specifically designed for the extra weight of a Side x Side.
  • — Vantage 4000: 55′ of 7/32″ aircraft-grade wire rope and a roller fairlead.
  • — Vantage 4000-S: 50′ of 7/32″ lightweight, easy-to-handle synthetic rope and a powder-coated hawse fairlead.
  • — Includes dash-mounted control switch and corded remote.
About Warn Industries
Warn Industries is the world’s most recognized brand in off-road products such as hub locks and vehicle recovery winches. The company designs, manufactures and markets a full line of off-road equipment and accessories that enhance the performance of four-wheel-drive and powersport vehicles. Warn Industries has employees in and around Portland, Ore., Livonia, Mich., and the Netherlands.
