The LEDP10W-240E LED High Intensity LED Light Bar from Larsonelectronicsllc.com closes the gap between LEDs and traditional metal halide lamps with 20,640 lumens of high quality light output. Designed for extreme conditions and fully waterproof, these high performance LED light bars offer performance comparable to HID light fixtures without any of the high heat or fragile construction that can make HID lighting a less then reliable lighting option in commercial work conditions.
The LEDP10W-240E LED Light Bar is designed to provide an extremely rugged and long lasting alternative to traditional forms of industrial and commercial HID lighting options. Producing over 20,000 lumens of high quality light output, these extreme duty LED light bars produce light output that matches the light output of comparable metal halide lamps, yet is far more durable, more reliable, and last longer. Unlike metal halide and other HID lamps which require a warm up period before they reach full intensity, the LEDP10W-240E produces full light output the moment it is switched on. Additionally, unlike HID lamps wh
ich must cool down between on and off cycles, this LED light bar can be switched on and off without any need for a cool down period in between. Constructed of extruded aluminum with an unbreakable polycarbonate lens, waterproof to 3 meters of submersion, and fitted with twenty four CREE XLamp MC-E®10 watt LEDs, these light bars can easily withstand the demanding conditions found in industrial work applications or offshore marine operations. The CREE LEDs in these units provide excellent light output with over 20,000 lumens of light produced at a color temperature of 6000K, making these LED lights well suited for applications which require lighting that provides above average detail rendering and contrasting. These lights contain advanced LED drivers utilizing pulse width modulation technology to allow operators to connect dimmers and pulse controllers in order to cause the lamps to dim, flash or strobe as desired. These same advanced drivers also provide built in voltage management and active heat control which allows these units to be operated with any voltage ranging from 9 to 48
VDC and helps to keep the LEDs running cooler for a longer operating life. These LED light bars can be configured for spotlight or flood beam style output, and spot light configurations will produce a beam reaching over 1400 feet in length. These light bars also include heavy duty mounting hardware that provides adjustable installation options and vibration reduction, allowing operators to install them on a wide variety of vehicles, boats and heavy equipment. These lights are particularly popular with commercial fisherman and industrial operators because of their very high output and ability to withstand demanding and abusive conditions.
“With lower power consumption and less heat generated, the LEDP10W-240E is a more versatile and economical solution for brighter working areas than metal halide and high pressure sodium lamps,” said Robert Bresnahan of Larson Electronics’ LLC Larsonelectronicsllc.com “At Larson Electronics’, we continue to develop new LED lights to help our customers extend their field of view for work, safety, and reliability.”
Larsonelectronicsllc.com produces a full range of LED lights, LED work lights, LED boat lights, intrinsically safe LED lights, and explosion proof LED lights. The Larson Electronics family of brands can be found on Magnalight.com, LXFlashlights.com and Larsonelectronicsllc.com. You can also call 1-800-369-6671 to learn more about all of Larson Electronics’ lighting products or call 1-214-616-6180 for international inquires.
