Metalcloak’s 3.5 Duroflex Cherokee XJ Suspension System
Metalcloak Duroflex 35 Suspension - CherokeeMetalcloak brings the undisputed success of the Duroflex Joint to Jeep Cherokee, XJ, owners with the 3.5″ Duroflex Suspension System. The patent pending Duroflex joint offers the vibration dampening of a rubber bushing with the high-misalignment of a ball joint – all housed in adjustable chromoly control arms.  Add the industry’s leading Dual Rate coil springs with the longest extended length and you have the ultimate on and off-road set up. Adjustable Front Bump Stop System provides the option of 1” to 4” in Bump Stop for proper tire clearance. System includes everything you need including steel-braided, Kevlar-lined front & rear brake lines, solid chromoly front track-bar, sway bar disconnects, replacement shackle bushings, rear bump stop kit, grade-8 u-bolts, complete replacement rear leaf packs, and all the hardware needed for installation.  Comes with front and rear ARB-Old Man Emu shocks.
Experience the Metalcloak Duroflex Suspension difference. Metalcloak, It’s Your Jeep, Only Better.  Information:  MetalCloak, 916-631-8071, www.MetalCloak.com
Branded & Cropped Cherokee at Prairie City - Filtered
