Trail-Gear is now offering 4.16 and 4.90 Jimny T-Case Gears
by / 0 Comments / 455 View / March 3, 2016
This is the first and only true international gear set that includes all four gears necessary for your low range gear installation.
Low range gears are critical for technical off-road driving. Our Jimny T-Case Gears is the highest quality gear set available. Low Range reduction is 4.16:1 (84% low range reduction & 12% high range reduction) or 4.90:1 (115% low range reduction and 16% high range reduction). No welded or second rate, gears here. These are strong, run quiet and take a huge amount of abuse. This complete kit includes four new precision cut gears, counter shaft, needle bearings, shims, o-ring, gaskets, and input/output seals. Heavy duty front output shaft recommended (see below).
Note: The recommended tire size for the 4.16 gears is 29”-30” and 30”-31” for the 4.90 gears.
Note: Will not fit in Jimny chain-drive transfer cases.
Application Data:
 1990-1995 Suzuki Jimny JA11 4WD
 1995-1998 Suzuki Jimny JA12 4WD
 1986-1990 Suzuki Jimny JA71 4WD
Available Options:
 4.16 Jimny T-Case Gears, 303924-3-KIT, $418.95
 4.90 Jimny T-Case Gears, 303925-3-KIT, $523.95
