For Sale: 1983 Jeep cj7, Wide Open Design Tube Buggy, $65K OBO
Wide Open Design chassis, 1983 Jeep CJ7 body. This is a complete custom buggy build using a Wide Open Design "JC" tube chassis. Front and rear Crane 14 bolt axles built new from Crane Axle/Wide Open Design with ARB air lockers. 4-link suspension features 7075 Aluminum links, QA1 chromoly rod ends, Radflo 2.0 coilovers, Radflow 2.0 bump stops and front and rear Anti-Rock sway bars. Front & rear driveshafts (Canyon Crawler) were custom built by J.E. Reel. Super Swamper TSL SX Stickies are like new (43"x 14.5"x 17") with Raceline bead lock wheels and Power Tank Monster Valves. Also includes spare wheel (same as main wheels) with new Mickey Thomson Baja Pro X tire (43"). Full aluminum skid plates from WOD with 3/4" UHMV custom cut from WOD skid plat CAD drawings. Engine is a GM Performance LS3 Hot Cam with 480HP. Engine only has 2,760 miles on it. Transmission is a GM 4L60e custom built by PerformaBuilt Transmissions supporting up to 700hp. Trans controller is a HGM, Computshift Sport TCM. TCM is controlled and programmed by blue-thooth and Compushift App. Transfer case is a Atlas 2 speed (3.8:1). Steering is from Radial Dynamics and full hydraulic. Brakes are hydro boost from Busted Knuckle. Engine and trans wiring harness were custom built by PSI. Engine has been custom tuned by Houston House of Power. Body wiring harness was new from Painless. Gauges are all from Dakota Digital and all brains are hidden behind fold down door in the custom dash. Has ARB twin compressor to run lockers and on-board air. Has console stereo with blue-tooth from SSV works. SPOD, Bantam X HD electrical switch panel. Rock lights from Lux Lighting Systems and can be controlled from app or SPOD. Vintage Air, Gen II heater with defrost. Rugged Radios RK-RDM-DB, VHF, UHF and GMRS, 45 watt GMRS, 50 watt VHF. Hood if fiberglass from Chris Durham Motorsports, Master Craft Baja RS seats, 5-point harnesses. Includes Bestop half/full soft doors. Dash and console custom build by Double D Fabrication. Interior of body is lined with rubber chips (not sure what the official name is) Includes a lot of spare/other parts. I have a complete build sheet with part numbers etc. axle build blue prints etc on this buggy available to serious buyers. Buggy comes with soft doors and a newer cab cover for covering up at night. I am not interested in trades of any kind. The Jeep is located in the Houston area. If you can see this add, its available.Dimensions (Approx)114" Wheelbase160" overall length89" total rear width92" total front width22" belly height. Lots more photos available. 65k. Located near Houston, TX
Is the CJ still available?
