First Generation 4Runner Rock Crawler for sale or trade
Turn key first generation 4runner for sale or trade. Odometer reads 277,XXX, previous owner said he rebuilt the engine shortly before I bought it. Unsure what mileage the engine was rebuilt. I unfortunately do not have the time to give this truck the attention it deserves anymore. Runs and drives flawlessly, ready to hit the trails.
Vehicle:
1987 Toyota 4Runner SR5
Body:
Bobbed 12 inches
Removable hard top bobbed to match
Interior bed lined
Autometer Phantom gauges
Power kill switch
Front Mastercraft racing seats
Mastercraft 4 point harnesses front and rear
2” x 4”x 1/4” rock sliders
4X Innovations quick release door hinge kit
Hella headlights
New body mounts
Engine: 22RE
LC Engineering Header
LC Engineering Ported throttle body
LC Engineering cold air intake
2 ¼” exhaust
Flowmaster muffler
CSF radiator
FAST I6 Ignition
FAST Coil
Flex-a-lite black magic electric fan
Odyssey AGM 34/78 Battery
Trail gear battery holder
GM 1 wire 150 amp alternator
Trail gear alternator bracket
4X Innovations motor mounts
Painless starter relay
New starter
New fuel injectors
New water pump
New radiator hoses
New Mass air flow sensor
New Throttle position sensor
New igniter
New distributor
Fuel System:
All fuel lines completely replaced
RCI 15 gallon fuel cell
Wahlbro 190 LPH inline fuel pump
Earl’s Performance fuel lines
Earl’s Performance fuel line fittings
Earl’s Performance pre and post fuel filters
New stock fuel pressure regulator
Painless fuel pump relay
Brake System:
All brake lines completely replaced (nickel copper lines)
Dual diaphragm brake booster
1” bore master cylinder
New clutch slave cylinder
Transmission: W-56
LC Engineering short shift kit
LC Engineering pro clutch
LC Engineering high torque flywheel
Transfer Case: Dual RF1A’s
Transfer cases completely rebuilt (all new gaskets, seals, bearings, and hardware)
Marlin Crawler MC08 dual transfer case adapter
Marlin Crawler 30 spline front chromoly output shaft kit
Marlin Crawler 30 spline rear chromoly output shaft kit
Marlin Crawler competition chromoly 21 spline 4.7 crawler gear kit (rear t-case)
Marlin Crawler chromoly 23 spline 2.28 crawler gear kit (front t-case)
23 spline t-case to 21 spline transmission output shaft adapter sleeve
NW Fab Trident triple stick shifter kit
Sky’s offroad dual transfer case skid plate
Sky’s offroad heavy duty transfer case mounts x2
Driveshafts:
Tom Wood’s front long travel driveshaft
Tom Wood’s rear driveshaft
Axles: Toyota 8” Low Pinion
Axles completely rebuilt (all new gaskets, seals, bearings, and hardware)
Front:
Marlin Crawler upper axle gusset
Marlin Crawler knuckle gusset kit
Marlin Crawler differential armor
RCV axle shafts (4340/ 300M)
RCV chromoly inner hub gears
Longfield chromoly outer hub gears
ARP Knuckle studs
ARP hub studs
Tail gear spindle stud kit
Yukon 5.29 gears
Yukon grizzly locker
Toyota V-6 4 piston calipers
Land cruiser vented rotors
Sky’s offroad high steer kit
Sky’s offroad U bolt flip kit
Rear:
Trail gear axle truss
Yukon chromoly axle shafts
Yukon 5.29 gears
Sky’s offroad rear disc brake conversion kit
GM metric calipers
Suspension:
All pro long travel leaf springs 5” (front)
All pro long travel leaf springs 6” (rear)
Sky’s offroad front spring hanger
Sky’s offroad rear spring hangers
Bilstein 5125 shocks
Wheels/ Tires:
Trail gear wheel spacers
39.5” x 13.5” x 15 Super Swamper Iroks
15 x 10 steel wheels
Total metal innovations 32 bolt bead lock kit
Total metal innovations inner bead stiffener
No rust, no smoke, no leaks, minor dents. Truck has been stored in a garage since I’ve owned it. Title in hand, all receipts in hand. Over 500 pictures available of the last 8 years of building this truck, feel free to reach out if you have any questions or would like more pictures.
Asking $30,000 OBO
Located in Puyallup, WA
Will trade for restored/ excellent condition classic muscle car/ truck of equal value, low mileage sports cars of equal value, or excellent condition/ low mileage 80 series Landcruiser
Delivery can be arranged depending on distance
Additionally, I will include all spare stock Toyota parts that I have acquired or that came off the truck:
2x sets of doors
Stock rear tailgate
Stock birfields
Stock hard top windows (sides, rear)
Stock SR5 seats
Spare transfers case parts/ housing
New bearings
New gaskets
New seals
Vehicle:
Body:
Bobbed 12 inches
Interior bed lined
Power kill switch
Hella headlights
New body mounts
Engine: 22RE
2 ¼” exhaust
Flowmaster muffler
CSF radiator
FAST I6 Ignition
FAST Coil
New starter
New fuel injectors
New water pump
New radiator hoses
New igniter
New distributor
Fuel System:
Brake System:
Transmission: W-56
Driveshafts:
Front:
ARP Knuckle studs
ARP hub studs
Yukon 5.29 gears
Rear:
Yukon 5.29 gears
GM metric calipers
Suspension:
Wheels/ Tires:
Asking $30,000 OBO
2x sets of doors
Stock rear tailgate
Stock birfields
Stock SR5 seats
New bearings
New gaskets
New seals
