2009 Jeep Wrangler Unlimited Rubicon — Full OffRoad Evolution Build | Dynatrac 60/80 Axles | 40s115k miles. Automatic. This is not a parts-bin Jeep with a lift kit and lockers thrown at it. This was built right, with a purpose, and it shows in every component.
The axles are the key here. Dynatrac ProRock 60 front and ProRock 80 rear with 5.38 gears and ARB Air Lockers front and rear. Most built JKs you'll see have a 44/60 setup or 60/60 at best. This runs the 60/80 combo... the same axle package that goes under a lot of KOH-level rigs. To go along with it: 1350 front driveshaft and a 1350/1410 rear shaft built specifically for the larger ProRock 80 joint. Everything in the drivetrain is sized correctly for what it's moving.
Suspension / Steering:
EVO Double Throw Down coilovers front and rear, EVO High Clearance Long Arm, EVO High Steer, PSC Hydro Steering with Synergy sector shaft brace. It drives on the highway as well as it performs on trail.
Tires / Wheels:
40" Nitto Trail Grapplers on 17" ATX Slab Beadlocks. Tires have good life left.
Armor / Protection:
EVO body armor and corner armor with tire carrier, EVO rear bump stops welded into the frame, EVO rear bumper with tow hooks, LOD welded-on rock sliders (not bolt-on), VKS aluminum high clearance front bumper. Rock Hard 4x4 cage with C-pillar. This rig is armored where it counts. EVO spare tire carrier (currently off the jeep for extra clearance).
Recovery / Air:
Warn winch with remote. Dual cylinder ARB compressor with air chuck... airing up after trails is easy. Including 4 way splitter
Electrical:
Full S-Pod system (recently redone) Rock lights. Flow lights on the hood. TrukLite headlights. Maxxima rear taillights. Dual batteries.
Interior / Extras:
BedRug front and rear carpet, tailgate table, lockbox under driver seat with key, floor mats, Best Top Trek-Top.Factory Rubicon features still intact: 4:1 transfer case, factory sway bar disconnect, factory remote start.
Recent maintenance:
Rear axle seal housing rebuilt. The S-Pod wiring was fully replaced — not patched, replaced.
Items that need attention:
The factory electric swaybar disconnect is going bad and needs to be replaced. I typically just disconnect the sway bar manually, but you could easily spend $150 on a manual sway bar disconnect. I just haven't done it. The spare wheel is on as I had sidewall damage to one tire. It'll need a new tire.
This thing drives great and has been an incredible rig. I have taken it 80mph down the highway with no issues. The cantilever rear suspension gives you a ton of extra clearance and articulation and eats up the bumps. Unfortunately, we have to do IVF for our next kid and so I need to sell this rig to fund that. Family comes first.
I wouldn't hesitate to take this rig anywhere. It's been built to go hard and maintained to keep going. My crew has fully built rigs, but most don't have AC / heat... and this does. It's a "luxury rig" in a lot of ways. Asking $40,000. Reach out with questions, happy to send more photos or walk through anything I can on the build. Located in Herriman, Utah.
Tires / Wheels:
Armor / Protection:
Recovery / Air:
Electrical:
Interior / Extras:
Recent maintenance:
