- Thread starter
- #31
I ended up mounting the fuel pump and filter under the driver side seat plate. Should be tucked up high enough.
Hoses will get a more permanent mounting solution later on down the road. Still in mock up..
Fabbed up the rear brake light mount. Rear View Mirror tacked into place as well.
Worked on the interior some more. Rear steer valve from RD will be living behind the driver seat.
I need to trim the atlas shifter mount 1-2" to clear the trail soda holders. And I tacked the orbital mount in backwards lol. Gotta fix that..
Heat shield under the passenger seat. Its upside down in the pic..
The reflective portion is doubled up with some Ti insulation sandwiched in between.
Temp sensor modification on the back of the engine block. Heated up the nipple, pulled it out, tapped it and plugged it.
the nipple was going to be in the way of the fuel lines and this bought me some clearance and cleaned it up a little.
Broke the temp sensor so a new one got installed.
