Finally there’s a solution to alleviate that problematic Jeep TJ transfer case shifting mechanism! Advance Adapters now offers a heavy duty shifter designed to correct the binding, hard shifts, and slipping-out-of-gear that is inherent when lifting a Jeep TJ or when altering the drivetrain components. The kit replaces the body mounted mechanical system with a robust cable actuated designed that creates a crisp and carefree shifting experience with your transfer case. P/N 715543-231 or 715543-241.
Advance Adapters now offers a new deluxe cable shifter upgrade for Jeep JK vehicles. This new heavy duty design was created for the off roader who is constantly shifting the transfer case in and out of various ranges. The improved cable & mounting system offers both a durable and dependable system that removes the easily worn out or broken factory cable system. P/N 715596.
For a while now, questions & anticipation has been building around the availability of the ‘next generation’ Atlas 4 speed. Well, wait no longer. Advance Adapters is happy to announce the re-release of this epic product. Some progressive features include a new planetary shift mechanism, the input gear & planetary shaft supported by tapered roller bearings to accommodate the higher thrust loads of larger engines & tires being used today, and a 300M output shaft. Still in development is a flat towing lubrication system which will be an upgrade option for all versions of Atlas cases.
