The Trail-Gear FJ80 knuckle rebuild kit contains all of the replacement parts you need to service your steering knuckles including gaskets, felts, seals, spindle nut & washers, and shims. New spindle bushings, trunnion bearings, and steel outer felt covers are also included. The stamped steel outer felt covers are not found in other most other kits. If you’re using your FJ80 in the rocks you will want to replace these covers when you service the knuckles. The FJ80 Knuckle kit has all the parts you need to service both left and right knuckles. Available with or without wheel bearings.
Available Options:
FJ80 Knuckle Rebuild Kit, 303441-1-KIT, $72.45
FJ80 Knuckle Rebuild Kit w/Wheel Bearings, 303749-1-KIT, $124.95
