Reflects heat away from fuel rail and injectors; reduces risk of fuel rail and injector heat soak
Avon Lake (September 18, 2015)…Design Engineering, Inc. (DEI) now offers a thermal Fuel Rail and Injector Cover Kit designed to custom fit 1997-2004 Jeeps® equipped with an inline-six engine (L6). Jeep Wranglers and Cherokees often are at risk of heat related fuel system problems that can cause rough idle or slow starting. DEI’s fuel rail and injector cover kit reduces rail and injector fuel temperatures; reducing instances of vapor lock. With thermal protection from radiant or direct engine heat, injectors will perform more efficiently with a more consistent throttle response.
The kit includes: 1 manifold heat shield, 1 fuel rail heat cover, 6 fuel injector covers and 12 fuel injector OE replacement O-rings. Both the heat shield and the fuel injector covers are made of high-temperature rated glass fiber material bonded to a heat reflective aluminized material. The fuel injector heat covers can be used for either stock or aftermarket fuel injectors. Easy to install, the injector covers feature a split design and sewn-in hook and loop fastening edge that takes only moments to install.
For more information about DEI’s Made in the USA Jeep Fuel Rail & Injector Cover Kit, (#010378) or other DEI thermal control performance products, visit www.DesignEngineering.com, call DEI at 800-264-9472 or e-mail: Sales@DesignEngineering.com. To keep up with the latest new products and news from Design Engineering, Inc. (DEI), like DEI on Facebook or follow DEI onTwitter.
Formed in 1995, Design Engineering Inc. (DEI) is a major U.S. manufacturer and supplier of high performance automotive aftermarket products selling worldwide to a large number of commercial markets – automotive and racing, V-Twin, Sportbike/Metric, ATV/UTV/Off-road, 12 Volt/Car Audio, Industrial, Marine, and Aeronautical.
DEI, located in Avon Lake, OH, specializes in the development of thermal and acoustic performance products as well as cryogenic intake systems and related accessories under the CryO2™ brand, nitrous oxide systems and accessories under the Ny-Trex™ brand, acoustical insulation and sound deadening products under the popular Boom Mat™ brand, as well as a full line of performance coolant additives under the brand Radiator Relief™.
