Trail-Safe™ Toyota Rear Axle Seals
Tired of dealing with oil leaks from your rear axle seals? Trail-Gear has remedied that issue by offering our new Trail-Safe™ Toyota Rear Axle Seals. The Trail Safe™ inner seal lip is totally supported by a garter spring applying constant force over the full 360º circumference. This prevents any deflection gaps and stops oil from bypassing the seal lip. The outer seal lip acts as a secondary seal and keeps debris and other contaminants away from the inner seal lip.
The O.D. of the Trail Safe™ Seal is 100% rubber coated so that it forms a complete static surface seal resulting in zero leaks, and the outer flange prevents the seal from being pushed too far into the axle housing. This is by far the most effective rear axle seal on the market, and will help you keep your favorite trails free of oil.
Note: This seal will not work on Rock Assault Toyota Rear Axles manufactured prior to November 23, 2015.
Application Data:
 1979-1995 Toyota Pickup (All Engines)
 1985-2002 Toyota 4Runner (All Engines)
 1993-1998 Toyota T100 (All Engines)
 1995-2004 Toyota Tacoma (All Engines)
 2000-2006 Toyota Tundra (All Engines)
Trail-Safe™ Toyota Rear Axle Seals, 303836-1-KIT, $15.75
