Check out the following video where experts on the new COMPUSHIFT transmission controller discuss its world-leading features and benefits. The COMPUSHIFT is a standalone transmission controller that allows you to run the transmission of your choice behind the engine of your choice. It is perfect for almost any conversion. It is IP65 rated, meaning it is waterproof and dustproof. The COMPUSHIFT is designed and built right here in America. It comes will a full stand alone wiring harness, optional display and unlike most other systems it is for the most part true plug and play, working straight out of the box. The system is tried and true having been developed in some of the hardest environments and toughest terrains in the past 15 years. The COMPUSHIFT is capable of running most 4 Speed transmissions and some 5 and 6 Speed and more in development. The COMPUSHIFT uses a world leading Bluetooth technology meaning all the setup, calibration and diagnostics can be done using a Bluetooth App on your phone or device. For more details on the COMPUSHIFT take a look at our dedicated COMPUSHIFT webpage. And don’t forget to check out the video below.
The post COMPUSHIFT Standalone Transmission Controller appeared first on IH8MUD.com.
