SOLD: KS/USA 1990 Jeep Wrangler YJ RockCrawler & 2017 Eagle Car Trailer
FOR SALE – 1990 Jeep Wrangler YJ Rock Crawler plus a 2017 Eagle Car Trailer. I am selling these as a set or individually. I’m asking $32,000 for the set or they can be purchased individually for $28,000 on the Jeep and $4,000 for the Trailer. Both have regular highway titles. Both are in nice condition with no major rust or mechanical issues, and have been stored inside when not used. Both have been professionally maintained by 4X4 Land of Topeka, KS and Eagle Trailer of Lawrence for maintenance, repairs, or modifications. The Crawler has had about $6,000 in equipment upgrades over the past 2 years. Pictures show ORI Struts but new King Coilovers were installed summer of 2023. Please call or text: Six two zero, four nine one, zero seven eight five. No trades or help selling.
ROCK CRAWLER EQUIPMENT
• Chevy 350 SB with Howell Fuel Injection & Mild Cam Roller Rockers
• Transmission – Chevy 700R4 w/overdrive
 Heavy Duty Coolers
• Aluminum Radiator
• Transfer Case – Atlas 4-Speed & Hi/Lo Planetary (Doubler)
• 14.50 x 43 x 17 Super Swamper Stickies and Raceline Wheels & Beadlocks
• Front & Rear Drive shaft are custom built.
• Front Axle – Chevy Dana 60 Chromoly inner & outer shafts w/CTM U-Joints
 Warn Lockouts (Also have a set of East Coast Gear Supply Drive Flanges)
 Detroit Locker
 5.13 Gears
 SOLID Diff Covers
• PSC Hydraulic Steering w/Heavy Duty Cooler (new hydraulic hose May 2023)
• Rear Axle – Chevy 14 Bolt
 Yukon Spool & Yukon Ring & Pinion (2022)
 5.13 Gears
• Brakes – 4-wheel disc w/heavy duty brake booster (New brake calipers all wheels in 2022 also new brake lines.)
• Lower Links – Aircraft Aluminum
• King Coilovers – installed July 2023
• TK 1 Racing Rear Sway Bar – installed Sept. 2023
• Full Plate Body Armor
• Rock Sliders are tied into Rear Fender Flares
• RCI 15 gal. Aluminum Fuel Cell
• NRG Removable Steering Wheel
• Front/Rear Corbeau suspension seats
 Front has 4-point harness
 Rear has regular seat belt
• Custom Roll Cage
• Mile Marker SI 9500 lb. Winch w/Custom Splice Synthetic Rope
• Rock Lights underneath plus LED light bar
• New Custom Dash – 2018
 Auto Meter Gauges – temp. gauge is mechanical and block mounted
 AM/FM Radio
 CB Radio
• New Wiring Harness & Fuse Block – 2018
• 116” Jeep Wheel Base
• ½ Door’s w/Windows, plus Vinal Top
• Custom Wrap – Installed 2021
• Jeep has operable head lights, turn signals, tail and brake lights, wipers, and a heater.
2017 EAGLE CAR TRAILER
• Manufactured and custom built in 2016 by Eagle Trailer in Lawrence, KS.
• Trailer bed is overall 18’ bed length including dove tail
• Axles are both 7000 lb.
• New wheel bearings both sides – 2023
• 2 spare tires
• LED lighting
• Left fender flare has slight damage from loading/unloading mishap depicted in picture
