1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Lift
Discussion in 'Wheelers Tech' started by Tyler, Aug 30, 2012.
  1. Tyler
    Tyler Member
    Aug 12, 2012
    8
    M looking for something that will give my axle Clarence and body clearance from rushing water. Should I go with a 2 inch suspension and a 3 inch body? I don't want to have to replace all the brake lines U joints etc.
  2. woody
    woody eternal noobie Staff Member Media Partner
    Oct 12, 2010
    492
    Wisconsin
    body lift still means the frame will be in the water...little advantage if that's what you are trying to solve...suspension lift is the best option, by far.
  3. Big Red 88
    Big Red 88 Active Member
    Aug 4, 2012
    42
    That's what I was gonna say woody, do it right the first time then you don't have to do it again later.
  4. hamhama7x
    hamhama7x New Member
    Nov 17, 2012
    3
    When you lift the body you make those mounting points much more vonerable to breaking and splitting from the frame, go with the supension lift, otherwise youll be paying for a whole lot more than the lift kit
