Extreme Outback Releases Ultra Light Aluminum Air Tank
Vacaville, CA – Extreme Outback Products created the Ultra Light 3.0 all-aluminum air tank for a severely weight-restricted military application. However, this 3-gallon tank — which weighs only 6 pounds — is ideal for any situation where lightweight air storage is needed. Custom-vehicle air-suspension systems is one obvious use, as are corrosive marine and off-road applications.
The Ultra Light 3.0 features five 3/8-inch outlet ports and a 1/4-inch drain port. The tank is built to DOT-standard 750-psi burst strength. Measurements are 7-inch diameter by 24 inches long. Standard finish is raw aluminum; polishing and powdercoating are available extra-cost options. Extreme Outback can also custom-make tanks to customers’ specs in both aluminum and steel.
For more information, please contact Extreme Outback Products, 866-447-7711, info@extremeoutback.com, www.extremeoutback.com.
