NEW UTV KIT SIMPLIFIES OFF-ROAD HEATER INSTALLATIONS
An Aqua-Hot 100 or 200 Off-Road Heater can make cold days more comfortable for off-road enthusiasts.  Aqua-Hot Heating Systems, the leader in hydronic heating systems for the RV industry for over 25 years, introduces the Aqua-Hot UTV Heater Installation Kit.  Compatible with most types of UTVs, the convenient, universal kit provides all the components required to quickly and easily mount an Aqua-Hot Off-Road Heater.
The versatile Aqua-Hot UTV Heater Installation Kit features Aqua-Hot’s new Diverter Manifold that enables the Aqua-Hot Off-Road Heater to be plumed directly into the UTV’s radiator hose.  The innovative Diverter Manifold bypass design reduces engine overheating, while maximizing heater output.
Connecting to an engine’s cooling system, the compact Aqua-Hot Off-Road Heaters quietly and efficiently heat cabs with a brushless, radial axial fan.  Delivering big heat from a small package, they weigh only 3.5 lbs. and measure just 5.5″ H x 5.5″ D x 9.5″ W.
A tough, high-strength nylon 6/6 housing resists harsh elements and challenging environments.  An adjustable mounting bracket rotates 180° for easy installation to the floor, firewall or under dash.  Slotted mounting arms and a serrated clamp ensure a tight fit.
Ideal for larger UTVs, off road equipment enclosures, Jeeps and larger off road vehicles, the Aqua-Hot 200 Off-Road Heater draws from 0 to 2 amps, ensuring long hours of warmth without draining the battery.
Aqua-Hot 100 is perfect for two-person UTV cabs, small utility tractor enclosures, supplemental rear heat in Jeeps and larger vehicles where battery power is limited.  The economical unit draws less than 0.5 amps, and can be set from 0 to 100 cfm.
The Aqua-Hot UTV Heater Installation Kit has a suggested retail price of $189.99.  With a one-year warranty, the Aqua-Hot 100 Off-Road Heater costs just $189.99, while the Aqua-Hot 200 is $219.99.
Contact Aqua-Hot Heating Systems, 15549 E Hwy 52, Fort Lupton, CO 80621.  Toll free: 800-685-4298 or 303-659-8221; Fax: 303-857-9000.  marketing@aqua-hot.com; www.aquahotoffroad.com.
