Harbor Freight Introduces: BADLAND WINCHES!
We are thrilled to introduce Badland Winches, a brand new line of six professional grade winches available at low Harbor Freight prices that we are sure the readers of Rock Crawler will find exciting!
Badland Winches have it all:
  • SPEED – a three stage planetary gear system for blazing fast line speed
  • POWER – from high strength aircraft-grade cables to a new efficient, maximum-pull, low amp draw Neutron Motor
  • HIGH END FEATURES – including a new Everyuse Bolt Pattern to fit every mount, ergonomic Pistol Grip Handheld Controls, an automatic load-holding brake, free-spooling capability and a new Easy Turn Clutch Knob
  • QUALITY – including a High Alloy Steel Internal Gear Train, heavy duty industrial hook and cable assemblies, Salt Spray Resistant Coating tested to withstand the toughest weather and centered frame construction for optimal balance and handling
These heavy-duty Badland Winches are available for ATVs with 2000 lbs., 3000 lbs., and 5000 lbs. capacity, and for Off-Road Vehicles in 6000 lbs., 9000 lbs., and 12,000 lbs., and are base priced from $119.99 to $599.99.
