JK Wheel Adapter, Dodge 8 Lug Wheel Spacer – Rough Country Suspension Systems
Roll Your Own Way – Jeep JK Wheel Adapter and Dodge 8-Lug Spacer
DYERSBURG, TENNESSEE— Rough Country’s new JK Wheel Adapter will revolutionize the way you roll. This simple adapter allows you to run previous model wheels on Jeep JK’s. Why bother with the limited options and higher cost of newer wheels? This adapting spacer retrofits your JK’s existing 5X5″ bolt pattern to a 5X4.5″ bolt pattern, affording you the ability to run TJ, XJ, and YJ wheels. This bolt-on adapter also acts as a 1.5″ wheel spacer, allowing use of a wider tire on stock wheels and giving your vehicle an aggressive look. Made of 6061-T6 Aluminum, these wheels are corrosion resistant and ready to withstand the elements. Retails for $59.95.
Also new from Rough Country is the Dodge 8-Lug Wheel Spacer. Run larger tires on your Dodge with Rough Country’s 2″ Wheel Spacer. This 2″ spacer helps offset the wheel from your truck’s suspension, allowing use of a wider tire and giving a meaner overall look. This 8-lug spacer fits a 8X6.5″ Bolt Pattern supporting 9/16″ studs. Made of 6061-T6 Aluminum, it is also corrosion resistant. Retails for $109.95.
Formed in early 1970’s, Rough Country Suspension® Products was a founder of the off-road industry and is one of the fastest growing manufacturers and marketers of lifted suspension packages and off-road accessories for 2wd and 4wd trucks and SUVs. Rough Country Suspension® Products is owned by Heckethorn Products® which boasts a rich history in the automotive aftermarket, including the invention of the first steering stabilizer for military Jeeps in the 1950s. As a complete supplier, Rough Country Suspension Products offers retailers, wholesalers, and consumers an opportunity to purchase easy to install off-road products the market is demanding.
CONTACT:
1400 Morgan Rd.
Dyersburg, TN 38024
800-222-7023
www.roughcountry.com/
