The Safari SS1140HF snorkel is tough and stylish and has been designed to deliver a huge volume of the coolest and cleanest air possible into the standard air cleaner assembly of the Jeep Grand Cherokee WJ.
Like other Safari Snorkel designs, the Grand Cherokee WJ snorkel system was designed to exceed the air flow requirements of both the 4.0 & 4.7 Liter engine. The Safari Snorkel system is designed to breathe freely in order to deliver the greatest air flow performance possible for even highly modified engines.
The Safari Snorkel body and air ram are manufactured to the highest standards in durable, UV stable, cross linked polyethylene material. In addition, the substantial material wall thickness delivers huge physical strength to ensure that the snorkel breezes through the toughest off-road conditions on the planet.
An accurately marked template is also provided to ensure that the installation of the snorkel body to panel work is as precise as possible.
All Safari Snorkel systems are supplied as a complete and comprehensive system that includes every nut, bolt and bracket required for installation – right from robust zero-corrosion stainless steel studs, self-locking nyloc nuts and large diameter anodized body washers through to the tough plastic A-pillar inserts.
