AMSOIL Reformulates Synthetic Water-Resistant & Multi-Purpose Greases
amsoilAMSOIL Synthetic Multi-Purpose Grease and Synthetic Water-Resistant Grease have been reformulated to provide even better protection and performance in a wide range of applications. Both are formulated with calcium sulfonate complex thickeners, allowing for improved extreme-pressure properties, corrosion resistance, oxidation resistance, high-temperature stability and water resistance.
AMSOIL Synthetic Water-Resistant Grease is an extreme-pressure grease formulated specially for wet-duty performance. It provides exceptional film strength, shear resistance, adhesion properties and mechanical stability. Excellent corrosion protection seals metal surfaces and chemically fights corrosion. Its water washout and sprayoff resistance are outstanding for applications frequently exposed to mud, water, snow or ice such as ATVs, UTVs, snowmobiles and boat trailers.
AMSOIL Synthetic Multi-Purpose Grease is qualified against the highest grease standards. Formulated with oil soluble extreme-pressure additives for heavy loads, it provides excellent load-carrying and EP performance. Oxidation and corrosion inhibitors provide excellent oxidation stability, a high-temperature dropping point and outstanding low-temperature torque value and pumping capability. It resists thermal and oxidation degradation, prolonging equipment life.
About the Company: AMSOIL has been the recognized leader in synthetic lubrication since 1972.  For more information about AMSOIL contact your nearest AMSOIL distributor, or call AMSOIL at (715) 392-7101 or 1-800-777-8491.  AMSOIL INC., 925 Tower Avenue, Superior, WI 54880, or go to www.amsoil.com.
