TRAIL-GEAR RELEASES ROLL CAGE AND SUSPENSION COMPONENTS FOR JEEPS
Fresno, CA-Trail-Gear, Inc. plans to shake things up with the launch of three new Jeep products. Trail-Gear will be debuting a new roll cage for Jeep Wranglers made from years 1987-1995 (YJs), front lower control arm brackets and cam bolts for Wranglers, Cherokees and Wagoneers with the following Body Style Designations: TJ; TJ-L or LJ; XJ; ZJ; and WJ, today (Friday, August 3rd). “We have a wide selection of off-roading products that every off-road enthusiast should have,” said Matt Messer, Trail-Gear CEO. In response to customer requests, Trail-Gear will be expanding into the Jeep market. “We saw a need for high-quality yet affordable Jeep parts in the market and want to be the one to fill it,” Messer explains.
Trail-Gear will be releasing their new Rock Defense™ YJ Roll Cage. It is a do-it-yourself, weld- together cage that adds-on to the existing roll bar. Made from heavy-duty 1.75”x .120” wall DOM material, it replaces the weak stock A to B pillar braces and offers more protection in the event of a roll during on and off pavement adventures. The Rock Defense™ YJ Roll Cage has been engineered for Wranglers made from 1987-1995. It fits YJs with either hard or soft tops and requires welding for assembly.
Trail-Gear will also be releasing their Jeep Front Lower Control Arm Brackets. These brackets are designed to upgrade the stock front lower control arm brackets on TJ and TJ-L or LJ Wranglers and XJ, ZJ and WJ Cherokees or Wagoneers with Dana 30 or 44 front axles. The Trail- Gear brackets are made from heavy-duty ¼” thick steel and will strengthen the suspension mounting points, allowing drivers to take on bigger obstacles on the trail. Brackets are sold in pairs.
Additionally, Trail-Gear will be releasing a set of heavy duty Jeep Cam Bolts so that customers may upgrade their stock bolts when upgrading their brackets, instead of re-using the stock bolts. The Trail-Gear HD Jeep Cam Bolts are specially engineered to fit Jeep Lower Control Arm Brackets on TJ and TJ-L or LJ Wranglers and XJ, ZJ and WJ Cherokees or Wagoneers with Dana 30 or 44 front axles. They are rated Class 10.9 and zinc-plated for corrosion resistance. Each kit includes hardware for both Lower Control Arm Mounts which includes two bolts, two lock nuts and four Cam washers.
Interested parties may purchase the Trail-Gear Rock Defense™ YJ Roll Cage, the Jeep Front Lower Control Arm Bracket and the Jeep HD Cam Bolts from any authorized Trail-Gear dealer or via the Trail-Gear website (www.trail-gear.com). The Trail-Gear Rock Defense™ YJ Roll Cage retails for $239.99, the Jeep Front Lower Control Arm Brackets retail for $69.99 and the Jeep HD Cam Bolts retail for $34.99 on the Trail-Gear website.
All design and development for the Trail-Gear Rock Defense™ YJ Roll Cage, the Jeep Front Lower Control Arm Brackets and the Jeep HD Cam Bolts were done at the Trail-Gear, Inc. world headquarters in Fresno, California. Manufacturing for the Rock Defense™ YJ Roll Cage and Jeep Front Lower Control Arm Brackets is also done at the Trail-Gear headquarters in Fresno, California.
