FOX releases two new products that will increase performance and control Jeep Wrangler JK.
El Cajon, Calif. – Two exciting new products for Jeep JKs from FOX are ready for release. The first is a revolutionary steering stabilizer that incorporates both innovative design and function.
The FOX Performance Series Adjustable Through Shaft (ATS) steering stabilizer offers unrivaled steering control and a striking high tech appearance. The technologically advanced design cancels unwanted steering forces in both directions, taking the place of two conventional opposing stabilizers. It will also respond to your input with 24 clicks of external adjustment to fine tune the feel. The integrated reservoir allows for additional fluid capacity and improves cooling during extreme use. Also included is FOX’s relocating hardware that moves the steering stabilizer up and out of the way utilizing a new track bar relocation bolt and tie-rod mounting clamp. The ATS represents a revolutionary breakthrough in stabilizer design.
Also ready for release is a direct replacement 2.5, Factory Series, Internal Bypass shock for Jeep JKs with 2.5 – 4 inch lifts. The new shock allows you to bolt on the same race-dominating, position sensitive damping technology utilized in our championship winning Trophy Truck shocks. FOX’s patented position sensitive, Internal Bypass technology is designed to maximize performance throughout the entire range of wheel travel. Position sensitive internals contain passages that allow fluid to bypass the piston through regulated ports as it cycles. Your JK will deliver maximum control in rougher terrain and a bigger grin on your face.
For more than three decades, FOX has been the industry leader in the design and development of high performance shocks absorbers for off-road cars and trucks. That tradition continues with the release of these latest products designed to enhance your driving pleasure in any terrain.
FOX 2.5 Performance Series ATS Stabilizer Reservoir
Jeep Wrangler JK 983-02-070 $395.00 retail
FOX 2.5 Factory Series Internal Bypass Reservoir
Jeep Wrangler JK (Front) 883-02-068 $1195.00 retail (SET)
Jeep Wrangler JK (Rear) 883-02-069 $1195.00 retail (SET)
