ARB Rear Bar and Tire Carrier For Jeep TJ / YJ
233The latest TJ/YJ Jeep ARB rear bar has been designed to be simple and light weight with the ability to add a swing away tire carrier that takes the weight of the wheel off the rear door.
Features:
  • The rear bar can be fitted as a protection device on its own, allowing the original spare to remain mounted to the rear door.
  • Alternatively, the rear bar can be optioned with the new “catchless” design tire carrier which can carry up to 35 inch spare tire and rim combinations.
  • Incorporates two 20mm recovery eyelets designed to receive a 5.25 ton shackle pin and two Hi-Lift jacking points.
  • The tire carrier (common to TJ/YJ and JK) includes a mounting bracket for the factory/OE fog light or aftermarket backup light.
In Stock and shipping!
http://library.constantcontact.com/download/get/file/1102593731013-236/TJ-YJ+Rear+Bar_Retail.pdf
