With seating for 5 and outstanding rugged performance, the JK Jeep Wrangler Unlimited (4-door) is a capable vehicle on and off road. It gives owners plenty to smile about but throws up some challenges when considering storage. In order to make the most of the JK’s cargo area and maximize storage and flexibility of use, a new roller drawer module has been developed. The RDRF790 incorporates a single Roller Drawer and an integrated Roller Floor top. The design allows for plenty of accessible and secure storage in the drawer. While the roller drawer function is self-explanatory, the roller floor provides easy access to a Fridge Freezer or other gear. The 37 quart ARB Fridge Freezer (10800352) can be mounted in the traditional front to back orientation. Although a tight fit, a 50 quart ARB Fridge Freezer (10800472) can be oriented left to right across the drawer and rolled rearwards for easier access.
Outback Solutions Modular Roller Drawers have unique and practical features incorporated into their design to ensure high
quality, maximum functionality and ease of use.
ANTI ROLL BACK SYSTEM
The RDRF790 incorporates mechanisms on both the roller drawer and the roller floor that lock them in the open position, preventing unintentional closing when the vehicle is on uneven ground. The mechanisms engage at full opening of the roller drawer or roller floor and are disengaged automatically when closing.
ANTI RATTLE
Locking mechanisms on the roller drawer and roller floor eliminate movement while closed. Retaining the drawer and roller floor in this way prevents rattles and wear and tear while driving.
PURPOSE FOLDED STAINLESS STEEL RUNNERS
The roller drawer and roller floor bearings run on purpose-folded stainless steel runners. Smooth operation is ensured because stainless steel offers the best surface for bearings to run on resulting in smooth quiet operation. Galvanized bearing runners are not used because the galvanized coating transfers onto the bearings creating rough operation and an opportunity for corrosion to start. Tool chest style telescopic runners are not used because of the slop and movement they allow. This constant movement while driving accelerates wear and deterioration when used in automotive applications.
UV STABLE COMMERCIAL CARPET
Exterior surfaces are finished in hardwearing commercial carpet and interior surfaces are trimmed in an automotive trunk material. Both materials resist abrasion and conceal dirt from gritty off-road conditions.
ROBUST FINISHES
Aluminum and ruggedized plastics are used to mirror the tough nature of the Wrangler.
SLAM SHUT LATCHES
Slam shut/pull open handles make opening and closing both the roller drawer and the roller floor an ease, even with hands full of gear. The roller drawer handle is key lockable and the roller floor has a mechanical lock under the top behind the handle. The roller floor can be locked before closing and key locking the drawer to provide good security.
RDRF790 DRAWER MODULE SPECIFICATIONS:
- Drawer Internal Dimensions 730 mm (28.7”) Wide X 655 mm (25.7”) Long X 220 mm (8.6”) Deep
- Drawer Extension Travel 400 mm (15.75”)
- Roller Floor Extension Travel 403 mm (15.87”)
- Weight 48 kg (105.82 lbs)
SIDE FLOOR KITS:
The side floor kit is a recommended optional fitment with the RDRF790 drawer module and fills in the area between the outer edge of the drawer and the sides of the vehicle’s interior trim. The side floor kit completes the floor and provides a larger flat top surface while maintaining access to the wheel arch storage areas. Each side floor kit contains both left and right hand side floors. JK side floors include stainless steel locking tabs to locate and retain the removable floor. Removal is via a simple latch located at the rear edge of the floor. The combination of stainless steel tabs and a simple, straightforward latch yields an easy to use and secure storage area. For models with plastic trim and a sub woofer, space is maintained around the sub woofer to maximize sound output. Access is retained to the factory 12-volt power connection on models with this OE feature. Two side floors are available, one to suit the vehicles with only a carpet rear trim and another for vehicles with plastic rear trim, with or without sub woofer.
INSTALL KITS:
The install kit provides an attractive removable carpeted cover panel over the jack and tool storage well. Removal is via two thumbscrews.
About ARB
ARB Marketing, ARB 4×4 Accessories 720 SW 34th Street, Renton, WA 98057
Tel: (425) 264-1391 | Fax: (425) 264-1392 | marketing@arbusa.com
