If you plan on taking your rig down the toughest trails, lower transfer case gears are essential. Nothing worse than hitting the trail and not having enough power to push your oversized tires. Our Trail-Creeper 4.24:1 T-Case Gears is just what you need! Our Trail-Creeper 4.24:1 T-Case Gears are constructed out of high quality materials for superior strength and to take the punishment that any trail has to offer. These gears provide a 135% low range reduction from the stock 1.8:1 gears giving you the power and control needed to conquer the most difficult of obstacles. The Trail-Creeper 4.24 T-Case Gears will also include input and output seals.
Why buy Trail-Gear 4.24 Gears?
• High Quality Materials
• Precision fitting spline fit for long life
• 135% gear reduction for more power and control on the trail
A full-color set of instructions is also included in this kit! This is the only full set of instructions out
there on the market for the 4.24 gears.
Note: Clearancing inside your t-case is required for installation
Application Data:
• 1991-1998 Suzuki Sidekick 4WD
• 1991-2001 Geo Tracker 4WD
• 1991-2001 Chevy Tracker 4WD
• 1995-1997 Suzuki x90 4WD
• 1999-2001 Suzuki Vitara 4WD
Trail-Creeper 4.24 T-Case Gears, 302882-3-KIT, $576.45
