As a driver you know brakes are one of the most important pieces of equipment on your race vehicle. Giving you the confidence to brake later into a corner consistently, a great braking system allows you to push harder and drive faster; which could be the difference between the top step of the podium and the others.
Alcon’s range of brakes include those specifically designed to suit the needs of the off-road racer. Alcon understands that off-road racing demands a lot from all components and has developed brakes to meet this demand. Every design is incredibly robust and durable, without sacrificing any performance, in order to withstandhe rigors of off-road racing. Using knowledge developed over years at the pinnacle of motorsport, Alcon’s Unlimited Truck packages offer incredibly reliable brake systems capable of battling through the harshest conditions.
Get to Know the Alcon Brake Systems:
-Bleed screws are recessed and fitted with caps for protection and to keep them clean.
-Stainless steel pistons with wear-resistant coating.
-High Temperature seals.
-3kg anti-knock back springs.
-Hard stainless steel wear plates.
-Removable central bridge for ease of pad change.
-Internally ported, no external fluid transfer pipe.
-Pads 0.64” thick
-Disc 12.75”
-Fixed pad retainer bars to increase stiffness,
-Monobloc 6-piston radial mount caliper, large braking force, staggered pistons to allow even pad wear.
-Fitted with wiper seals to prevent dirt ingress
-Stainless steel pistons available as an option to reduce heat transfer to brake fluid. stainless steel pistons with wear- resistant coating for reduced thermal transfer.
-Pads 1.12” thick
-Disc 14” Diameter
Alcon is renowned across the world for its specialist brake and clutch solutions. Providing the stopping power within the top echelons of motorsport, Alcon’s expertise and knowledge is second to none. As well as motorsport of all forms, Alcon is a highly respected manufacturer of both aftermarket and OEM brakes and clutches.
Race-Dezert.com was created by off-road enthusiasts, giving off-roaders a place online to share information about the sport and culture of off-road racing. Based in Southern California, Race-Dezert.com highlights the off-road disciplines of desert racing, short course off-road, stadium truck racing, rally raid, rally racing and rock crawling.Our goal is to connect the world of off-road racing globally, bringing people together through the common denominator of off-road culture. Whether you are a racer, a promoter, a chase team member, a casual fan, or just interested in learning about off-road, Race-Dezert.com is a place where you can learn about the sport and culture of off-road racing.
