Trail-Gear’s TG Curved LED Light Bars are versatile and can be mounted on any vehicle ranging from trucks, cars, and UTVs. These lights are powerful enough to light up the darkest road or trail. The curved design of the TG Curved LED Light Bar not only looks futuristic, it also helps to spread out the light emitted from thelight bar to give you a wider range of visibility on the trail.
The TG Curved LED Light Bars have a combo flood and spot optics with 3W Cree LEDs with a color temp of 6500K (cool white). The lens on the TG Curved LED Light Bars is made out of shatter-resistant polycarbonate material to prevent any damage to the optics. The housing is made out of extruded aluminum for superior strength. The end caps and brackets on the light bars are made out of die cast aluminum that is powder-coated black. Rubber anti-vibration isolators are provided to prevent damage to the mounting surface. The brackets can mount to both tubes and flat surfaces. Each curved LED light bar include a 15” wiring pigtail (2×18-gage wire with outer jacket). The input voltage on the LED light bar is 10-30VDC.
TG Curved LED Light Bars are IP67 Rated.
Note: Covers sold separately. Opaque black covers may be required by law in your area.
Available Options:
TG Curved LED Light Bar, 20”, 303419, $197.35
TG Curved LED Light Bar, 30”, 303420, $261.45
TG Curved LED Light Bar, 40”, 303421, $313.95
TG Curved LED Light Bar r, 50”, 303422, $366.45
