Longfield U-Joint Rebuild Kits
303767-2-KITEven the toughest u-joints need rebuilding eventually and this kit is what you need to get the job done.  This kit is specifically designed to rebuild your Longfield 300M U-joints. This kit includes u-joint caps with brass bushings pressed in, cap grease seals, and c-clip retaining rings for one joint.
Note: Does not fit Longfield U-Joints with grease zerk in cap.
Note: Not for JK DANA 44. If ordering for use with OEM Dana 30 axles, you will need to reuse your stock
U-joint c-clips instead of the full-circle c-clips provided with the kit.
Available Options:
 Longfield Dana 30/44 U-Joint Rebuild Kit, 303766-2-KIT, $61.95
 Longfield Dana 60 U-Joint Rebuild Kit, 303767-2-KIT, $61.95
