This is the first and only true international gear set that includes all four gears necessary for your low range gear installation.
Low range gears are critical for technical off-road driving. Our Jimny T-Case Gears is the highest quality gear set available. Low Range reduction is 4.16:1 (84% low range reduction & 12% high range reduction) or 4.90:1 (115% low range reduction and 16% high range reduction). No welded or second rate, gears here. These are strong, run quiet and take a huge amount of abuse. This complete kit includes four new precision cut gears, counter shaft, needle bearings, shims, o-ring, gaskets, and input/output seals. Heavy duty front output shaft recommended (see below).
Note: The recommended tire size for the 4.16 gears is 29”-30” and 30”-31” for the 4.90 gears.
Note: Will not fit in Jimny chain-drive transfer cases.
Application Data:
1990-1995 Suzuki Jimny JA11 4WD
1995-1998 Suzuki Jimny JA12 4WD
1986-1990 Suzuki Jimny JA71 4WD
Available Options:
4.16 Jimny T-Case Gears, 303924-3-KIT, $418.95
4.90 Jimny T-Case Gears, 303925-3-KIT, $523.95
