RUGGED RIDGE INTRODUCES THREE NEW LIGHTING MOUNT OPTIONS FOR JEEP TJ/LJ WRANGLERS
New Mounting Locations for Perfect for Extra Illumination on the Trails
Suwanee, Ga. (April 5, 2016) Rugged Ridge®, a leading manufacturer of high-quality Jeep accessories, today introduced three new lighting mount options for 1997-2006 TJ and LJ Jeep® Wranglers.
Designed to help Jeep owners easily add additional auxiliary LED lighting needed for nighttime trail rides, Rugged Ridge designed each new lighting mount options in a tough long lasting textured black finish.
Rugged Ridge TJ Hood Mount and Overhead Lighting Installed
  • The Windshield LED Light Bar Mount is constructed from sturdy two-inch welded steel tubing and is secured to the vehicle using specially engineered A-pillar brackets that replace the factory windshield brackets. The contour hugging light bar frames the windshield, accommodating three Rugged Ridge 13.5-inch LED Light Bars with low profile tabs.
  • The Hood Mount Light Bar supports up to five LED auxiliary lights. It mounts to the top of the Jeep’s hood using existing factory hardware and mounting points.
  • The Dual A-Pillar Light Mount brackets are constructed from heavy duty steel and are easily mounted to the lower windshield mount using existing mounting bolt holes. No drilling or cutting required for installation.
Rugged Ridge TJ Hood Mount Light Bar - Closeup
”We wanted to take the same light mounting versatility that we have for the JKs, and bring them to older model Wranglers,” said Chris Kudika, a Design Engineer at Omix-ADA. “The result is a reliable, convenient and affordable way to mount your lights for off-roading.”
The lighting mounts are backed by Rugged Ridge’s 5-year limited warranty and are available for purchase through select Jeep and off-road parts/accessories retailers nationwide.
For more information about the new lighting mount options for TJ/LJ Jeep Wranglers, Rugged Ridge’s complete line of high-quality Jeep and off-road products, or to find an approved retailer, please contact Rugged Ridge at 770-614-6101 or visit www.RuggedRidge.com.
Part Number Description MSRP
11232.08 Rugged Ridge Windshield LED Light Bar Mount, Textured Black
Fits 1997-2006 Jeep Wrangler TJ/LJ
$266.99
11232.09 Rugged Ridge Hood Mounted Light Bar, Textured Black
$100.99
11232.36 Rugged Ridge Dual A-Pillar Light Mount, Textured Black
$94.99
ABOUT OMIX-ADA, INC.
Omix-ADA®, Inc. is the world’s largest independent manufacturer and wholesaler of Jeep®, truck and off-road parts, accessories and floor liners. For more than two decades, Omix-ADA has designed, tested and manufactured more than 16,000 of the highest quality restoration and replacement parts and accessories. The Omix-ADA family of brands, Rugged Ridge® and Alloy USA®, are distributed throughout the USA and in more than 70 countries worldwide. For more information, please call Omix-ADA, headquartered in Suwanee, GA at 770-614-6101 or visit www.omix-ada.com.
Jeep® is a registered trademark of Chrysler Group LLC.
