RockCrawler.com Clayton Off Road High Steer System
Clayton-Off-Road-High-Steer-Kit.webpThe all new high steer system from Clayton Off Road is the only complete system that transforms your stock Jeep front axle and allows you to run a crossover high steer system with larger brakes & calipers, and improved ground clearance. Designed to work with high and low pinion Dana 30 and Dana 44 front ends, this kit will work with MJ, XJ, ZJ, TJ, and LJ factory axles.
The high steer system is complete, you don’t need to source brakes or unit bearings, or have anything machined. It allows you to retain your factory bolt pattern, as well as run RCV shafts with no modifications to the knuckles. There are no special tools required for install, but you will need to weld on a some new brackets. For more information and additional pictures of the kit installed visit our website or call us at (203) 691 8593.
The post Clayton Off Road High Steer System appeared first on RockCrawler 4x4 and Offroad Magazine.
  1. RCV Performance Products Introduces Jeep JK 300M Steel Rear Axles for High Strength, Stiffness, and Shock Resistance
  2. Steer Clear of Stabilizer Trouble on Wrangler JKs
  3. Economical High Powered LED Lights for On and Off Road Vehicles
