RockCrawler.com Doing Work with Vision X Lighting’s Duralux LED Series Lights
VisionX-DuraLux.webp February 7, 2014 – Auburn, WA – Vision X Lighting continues to expand it’s work-duty line-up with the new Duralux Series LED lights. Designed with fleet vehicles and working professionals in mind, each light combines durability and affordability for many on-the-job lighting needs. Available in 4 or 6 LED and 40 or 60 degree beam configurations, each light provides outstanding distance and more light output than a 100 watt halogen light. Each Duralux light only draws a mere 1.6A (12V) from it’s 5 watt premium LEDS, reducing power consumption, leading to fuel savings and lower operating costs. The rugged die-cast aluminum housing provides superior protection against the elements, and the universal single-bolt mount allows for a great range of adjustment. Each light is backed by the Vision X Lighting Extended Warranty for added piece of mind. For more information visit www.visionxusa.com or call 888-489-9820.
Duralux Series Features:
  • Available in 40° and 60° Beam Pattern
  • More Light than a 100W Halogen
  • Low Power Consumption, as low as 1.6A (12V)
  • 50,000 Hour LED Lifespan
  • Die-cast Aluminum Housing
  • Weatherproof Deutsch Connector
  • DURAE440 - Available with E-Mark Approval
Technical Data DURA 440/460
  • Warranty: Extended
  • Raw Lumens: 1,972
  • Effective Lumens: 1,380
  • Wattage: 20
  • Weight: 1.50 lbs/0.68 kg
  • LED Lifespan: 50,000 hours
  • Dimensions: 3.94” x 2.57” x 4.24” / 100 mm x 65.5 mm x 107.6 mm
  • Input Voltage: 11-65V DC
  • Amp Draw: 1.67A
  • IP Rating: IP-68
  • Vibration Rating: 8.6g rms
  • Operating Temperature: -40° Celsius ~ +80° Celsius
Technical Data DURA 640/660
  • Raw Lumens: 2,958
  • Effective Lumens: 2,071
  • Wattage: 30
  • Weight: 2.10 lbs/0.95 kg
  • Dimensions: 5.39” x 2.57” x 4.28” / 136.7 mm x 69 mm x 106.5 mm
  • Amp Draw: 2.5A
  • IP Rating: IP-68
The post Doing Work with Vision X Lighting’s Duralux LED Series Lights appeared first on RockCrawler 4x4 and Offroad Magazine.
  1. Vision X Releases New UM Round or Square LED Work Light
  2. Vision X Lighting Releases a New Generation of Solo Pods
  3. Vision X Lighting introduces Bolt On Light Mounts for ’07-’14 Jeep Wrangler JK
