RockCrawler.com Metalcloak’s 3.5 Duroflex Cherokee XJ Suspension System
MetalcloakDuroflex35Suspension-Cherokee.webp Metalcloak brings the undisputed success of the Duroflex Joint to Jeep Cherokee, XJ, owners with the 3.5″ Duroflex Suspension System. The patent pending Duroflex joint offers the vibration dampening of a rubber bushing with the high-misalignment of a ball joint – all housed in adjustable chromoly control arms. Add the industry’s leading Dual Rate coil springs with the longest extended length and you have the ultimate on and off-road set up. Adjustable Front Bump Stop System provides the option of 1” to 4” in Bump Stop for proper tire clearance. System includes everything you need including steel-braided, Kevlar-lined front & rear brake lines, solid chromoly front track-bar, sway bar disconnects, replacement shackle bushings, rear bump stop kit, grade-8 u-bolts, complete replacement rear leaf packs, and all the hardware needed for installation. Comes with front and rear ARB-Old Man Emu shocks.
Experience the Metalcloak Duroflex Suspension difference. Metalcloak, It’s Your Jeep, Only Better. Information: MetalCloak, 916-631-8071, www.MetalCloak.com
The post Metalcloak’s 3.5 Duroflex Cherokee XJ Suspension System appeared first on RockCrawler 4x4 and Offroad Magazine.
  1. Metalcloak’s Adjustable Rear Bump Stop System Makes Designing Your JK Suspension Easy
  2. Metalcloak Adds TJ/LJ to its List of “Game-Changing” Suspension Offerings
  3. MetalCloak’s 6Pak(TM) Upgrade Breathes New Life into Your Long Arm Kit
