Cracksrubi
Spotter Required
Anyone know what this sensor is called or who makes it seen it on the gram couldn’t find any more information
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I found out it’s a steer angle sensor for a tractor but this search led me down a whole nother rabbit hole. Now I need an electrical engineer or someone proficient with Arduino boards. I’ve had an idea for a while to simplify rear steer return to center now I just gotta figure out the box to control itCurious of this myself. If you find out, please share.
I’ve seen that used before I’m trying to learn the controller side of the rear steer electronics I’ve got an idea to use an off the shelf sensor that’s low profile and comes on a lot of cars and is cheap that should be stocked at most auto parts stores. The only only downside I’m running into is how to build my own controller to make it switch the rear steer valve I’m able to use an radio board to make it light up led using the sensor as a reference to angle but I still need to learn more to make it self adjust and stop. Currently I’m doing the input of work it’s just turning motion into lightAmazon.com: KAOLALI 52mm Rudder Angle Indicator Waterproof Gauge Meter 0-190 ohm with Mating Angle Sensor for Boat Yacht 52mm 9-32V Backlight(White Sliver) : Industrial & Scientific
Buy KAOLALI 52mm Rudder Angle Indicator Waterproof Gauge Meter 0-190 ohm with Mating Angle Sensor for Boat Yacht 52mm 9-32V Backlight(White Sliver): Electronic Indicators - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
